Electric VSS
As far as I am aware you must use cable with cable and electric with vss.
But maybe somebody who has been inside the clusters will know more but I doubt its possible to convert.
cable cluster=cable/mechanical VSS
electronic cluster=electronic VSS
*I'm sure you can convert cable to electric and vice versa if you happen to know a cluster guru out there but personally, I don't think it's worth the work. Stick with the basic, apples to apples, the way they're made.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">cable cluster=cable/mechanical VSS
*I'm sure you can convert cable to electric and vice versa if you happen to know a cluster guru out there but personally, I don't think it's worth the work. Stick with the basic, apples to apples, the way they're made.</TD></TR></TABLE>
Just wanted to make sure, thanks
That pic of the cluster shown is off the carbed 1.5L model out of Japan. The ZC cluster looks the same except has a redline of 7200rpm. I know cause i have an extra one lying around.
That cluster should be plug and play for you, there is no need to change it over to the vss unit, which i don't think could be done anyhow.
if your gauge cluster is cable man, you need to use your cable vss, not an electric one. even if its jdm. if a cluster is electric it won't have a place for a mechanical fitting on the back, like yours does.....
I know my cluster is cable and i was gonna stay w/ my cable VSS.
It was a general question to see if there was a way around using a electric vss on EF8/9 cluster.
<FONT COLOR="blue"> Since i have no use for this Electric VSS, It is up for sale</FONT>
https://honda-tech.com/zerothread?id=1107026
good information. i just had the same question because i hate having to deal with my cable vss every time i change my alternator. but i guess im stuck with the cable one. time for a new cluster.
peanut butter
Feb 18, 2008 04:00 PM
gsxr1k05
Sep 3, 2006 10:52 PM
3184, cable, cluster, convert, converting, crx, da, electric, electronic, hb, mechanical, sensor, speed, tokico, vss
