Suspension & Brakes Theory, alignment, spring rates....
Track guys what spring rates?
Old Jan 6, 2005 | 07:05 PM
Rostr02's Avatar
Default Track guys what spring rates?
What spring rates are all of the track guys running post them up for everyone. I am looking for the H1 cars mostly but give everyone an idea of what you are running.
Old Jan 7, 2005 | 05:13 AM
artifex's Avatar
say it
Default Re: Track guys what spring rates? (Rostr02)
a lot of HC racers run very high spring rates - 700-900 front and 1000-1200 rear (lbs/in).
Old Jan 7, 2005 | 06:36 AM
connvict's Avatar
Before next season gets going, i'm going to order some custom springs and run about 800/1000 (f/r). This is on my 98 Prelude.
Old Jan 7, 2005 | 07:29 AM
Mike_C's Avatar
what are you using the car for?
i daily drive and track my car, i'm on 7kf/9kr and i'm pretty happy with it. couldn't see going much higher in the rear without getting a new daily driver.
Old Jan 7, 2005 | 07:45 AM
AFFIRMED's Avatar
Im running the skunk2 launch kit 900rear and 400 front its a daily driver.
Old Jan 7, 2005 | 01:06 PM
Rostr02's Avatar
Default Re: (AFFIRMED)
this will basically be a track ***** I cant see driving a one piece front around pa. Just looking to get some ideas of what rates to run in the upcoming season
keep them rates coming
Old Jan 7, 2005 | 01:44 PM
STN_Pat's Avatar
Default Re: (Rostr02)
560/672
Old Jan 9, 2005 | 07:34 PM
Rostr02's Avatar
Default Re: (STN_Pat)
anyone elso on the track?
Old Jan 9, 2005 | 07:46 PM
.RJ's Avatar
.RJ
Depends on the shocks you want to use and your buget - if you have the budget for $$ shocks, you can run whatever rates you want... I would suggest getting a couple pairs of springs in 50-100# increments and doing some testing/tuning to see whats going to work best for you.
https://honda-tech.com/zerothread?id=553330
Old Jan 9, 2005 | 08:01 PM
George Knighton's Avatar
H-T Order of Merit
500/700 here, at the moment.
Old Jan 10, 2005 | 07:13 AM
Lo-Buck EF's Avatar
Default Re: (George Knighton)
672/338 junk with a big rear bar
Old Jan 10, 2005 | 07:26 AM
RacerBowie's Avatar
Street/Track CRX Si
300F / 400R 22mm rear bar.
Old Jan 10, 2005 | 08:05 AM
577HondaPrelude's Avatar
Default Re: Track guys what spring rates? (RacerBowie)
track only prelude
Front 800 lbs/inch (no anti-sway bar)
Rear 1000 lbs/inch (25mm Anti-sway bar)
Old Jan 10, 2005 | 01:01 PM
rudeman85's Avatar
Default Re: Track guys what spring rates? (577HondaPrelude)
480/600
Old Jan 11, 2005 | 09:23 PM
Rostr02's Avatar
Default Re: Track guys what spring rates? (rudeman85)
i was thinking about 700 front 800 rear byw i have kw varient 3's
Old Jan 11, 2005 | 09:50 PM
slammed_93_hatch's Avatar
600f 800r (22mm rear bar) track only car, soon to be H4
Old Jan 11, 2005 | 11:51 PM
pearlcfcivic97's Avatar
does anybody know what the spring rates on skunk 2 coilovers are and where are you guys geting these springs with large rates from?
Old Jan 12, 2005 | 04:55 AM
.RJ's Avatar
.RJ
Default Re: (pearlcfcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlcfcivic &raquo;</TD></TR><TR><TD CLASS="quote"> where are you guys geting these springs with large rates from?</TD></TR></TABLE>
call ground control.
Anything over 400-500# is not going to be very comfortable and 'off the shelf' shocks wont handle it - you'll need a rebuild/revalve and most companies dont offer it (kyb, tokico, etc). Anything over 600-700# on the street is just stupid.
Old Jan 12, 2005 | 08:33 AM
bad-monkey's Avatar
450/550 on GC's and OTS valved Koni yellows. the konis can handle it, but eventually i'm going to a 800/1000 or something similar when the car becomes a dedicated track *****.
Old Jan 12, 2005 | 04:58 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: (bad-monkey)
This isn't made to hijack the thread...but wasn't worth making another "what spring rates" post.
I currently drive on AGX + Neuspeed sports (too soft of a spring for my taste), and plan on getting new suspension setup for the summer.
The car is def street but I will go to the road course, maybe twice a year.
I also will visit the drag strip few times this coming up summer.
The question: Is there spring rates that would benefit all kinds of driving that I will be doing this coming up year?
I know that drag suspension usually consist of big rates in the rear, but the way Hondas understeer, higher rates in the rear may benefit while road racing too.
I know for sure I will be using OTS Konis, with GC and was thinking about getting 350f/400r rates.
Comments very welcome. TIA.
Old Jan 12, 2005 | 05:10 PM
.RJ's Avatar
.RJ
Default Re: (tommy69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommy69 &raquo;</TD></TR><TR><TD CLASS="quote">I know for sure I will be using OTS Konis, with GC and was thinking about getting 350f/400r rates. </TD></TR></TABLE>
You will be fine
If using a somewhat low powered street car on street tires... I'm not sure how much a true "drag" suspension would help you at the drag strip anyways.
Old Jan 12, 2005 | 05:11 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">If using a somewhat low powered street car on street tires... I'm not sure how much a true "drag" suspension would help you at the drag strip anyways.</TD></TR></TABLE>
Indeed.
Old Jan 12, 2005 | 07:30 PM
does anyone know the rates on skunk 2 coilovers?
Old Jan 12, 2005 | 07:46 PM
jetydosa's Avatar
25 Year Member
Im running 500f/600r and Id say thats right at the limit for a daily driven car. I have the 23mm rear bar and the car rotates well but I can see going stiffer in the rear at some point.
Old Jan 12, 2005 | 08:49 PM
justBLZE's Avatar
Chopper 2 Hopper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlcfcivic &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know the rates on skunk 2 coilovers?</TD></TR></TABLE>
Skunk Coilovers -old - 400F/300R (L/L) for civic, 500F/400R for integra
Skunk2 Coilovers - new - 500F/400r (L/L)
