1994 - Both headlights went out at the same time
Old Jan 6, 2005 | 05:24 PM
maruch's Avatar
Default 1994 - Both headlights went out at the same time
Both lights went out at the same time, fuses and bulbs OK. Everything else on the turn signal works. Running lights, flashers and turn signals work also. Would the lighting relay under the hood in the fuse box cause this? Thank's, this is a great forum.
Modified by maruch at 6:35 PM 1/6/2005
Old Jan 6, 2005 | 06:31 PM
PrettyLude's Avatar
check the relays
Old Jan 7, 2005 | 07:27 AM
SpeedFreak77's Avatar
Default Re: 1994 - Both headlights went out at the same time (maruch)
You checked the headlights already?? It may sound wierd but I had both of my headlights go out at the same time. It was a first.
Old Jan 7, 2005 | 08:27 AM
Filthy Focker!'s Avatar
Default Re: 1994 - Both headlights went out at the same time (SpeedFreak77)
agreed it can definitly happen that both headlights go out at the same time. I have seen it also.
fs
Old Jan 7, 2005 | 08:56 AM
RUBZERK's Avatar
Default Re: 1994 - Both headlights went out at the same time (filthy_shovel)
This may help
Old Jan 7, 2005 | 11:24 AM
NBPcivic07's Avatar
Default Re: 1994 - Both headlights went out at the same time (RUBZERK)
would this apply to the lx model to of a 95<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">This may help
Old Jan 7, 2005 | 01:58 PM
maruch's Avatar
Thank You for your help. $19 relay. With two kids in college gotta save where I can. Thanks again.
Old Jan 7, 2005 | 02:00 PM
sj993's Avatar
Default Re: 1994 - Both headlights went out at the same time (crableg03)
Most of it would. Not everything like the sunroof and power driver's seat fuses.
russianswty
Jan 5, 2009 06:44 AM
1991 DA
Aug 13, 2006 09:16 PM
EF_ST@TUS
Aug 9, 2005 08:31 PM
