FS: OEM and Aftermarket Acura Integra Parts - Interior, Dash, GSR, Airbags, Speakers, Door Trunk Hat
Old Jan 6, 2005 | 03:42 PM
mr_mbuna's Avatar
Default FS: OEM and Aftermarket Acura Integra Parts - Interior, Dash, GSR, Airbags, Speakers, Door Trunk Hat
GSR VIN: JH4DC2387VS000464
LS VIN: JH4DB7551VS001340
OEM Honda/Acura
Nearly Complete Black Interior
Black trim piece, LNGL CTR PLR LWR, 84171-ST8-0000
Seat belt, TK-A73-J734, K3610, N6X14, E2013, E2012, N6X02
Handbrake assembly, incl. handle, boot, and mechanism, black 2001 coupe
Trunk liner, black coupe, Side L, 84651-ST8A
Headliner, coupe, grey
Sunvisors, pair, grey
Rearview mirror, grey/black, I-E6-007013 A88 I-e6-027013
Rear seat belts, triple set, sedan, black, CJ92X28, CJ91X15, TKA8AJ681
Front and rear grab handles, rear incl. garment hangers, grey
Seatbelt sliding adjuster, grey, pair
Overhead light console, grey, US Pat. 5108298, 5108314
Door handle, black, power, ST7-R and STR-7-220, 167 172 164 264
Trunk liner, right, black, 84601-ST8A
Black cloth seats, with brackets, sliders, and headrests
Black leather coupe door panels – free
Headliner, sedan, grey
Grey window trim, LNG R QTR, 84130-ST7A-2200
Grey window trim, LNG LH QTR, 84180-ST7-0000
Black trim, LNG ASSY RR PANEL, 84640-ST8-0000 (or) 84040-ST8-0000
Sunroof trim gasket
Door Garnish, GARN RH SEAT SIDE, 84141-ST8A-0000
Door Garnish, GARN LH SEAT SIDE, 84191-ST8A-0000
Door Garnish, LNGR CTR PLR LWR, 84121-ST8-0000
Seatbelt, TK-A73-J844, A7026, Sedan front black belt
Padding, grey/black cloth, rear sedan, CK-T84A0, RBS-LO3
Third brake light, PA+S/MAI STANLEY 050-9203B, ST8-8724
Grey sedan cloth rear deck with speaker covers
Full grey sedan carpet
Black plastic dead pedal
Trunk and gas pull **** trim piece, black plastic
CAP R BELT HOLE FR, 84122-ST8-0000, black plastic, sedan
Grey pillar trim, GARN RFR RLR, 84101-ST8-000, ST8R, sedan
Grey pillar trim, GARN LFR PLR, 84151-ST8-000, ST8L, sedan
Pad, grey black cloth, rear sedan, CK-T84A0, RBS-R04
Trim piece, CTR PLR UPPER, 84111-ST8A-0000, sedan
Change holder, black, felt-lined, ST7-ABS
Fuse access cover and plastic diagram, black plastic
Under-steering-wheel ignition cover garnish, LNG COWL SIDE RH, 83111-ST7-A000
Black glovebox, ST7L-A000, ST7LH, Locking
Gauge garnish, black, VISOR METER MPS
Center console rear with armrest and rear ashtray, 83401-ST0-0230
Center console front with cigarette lighter, ashtray, cupholders, for MT, 77291-ST7-A000
Cover, DR INST LWR MSP, 77311-ST7-A010, sedan
Grey plastic trim, GARN R RR PLR, 84131-ST8-0000, sedan
CTR PLR UPPER, 84161-ST8A-0000, sedan
Grey flex plastic trim garnish, miscellaneous
Cover rear BHD, 84512-SR4-0000
Upper steering column cover, black, 77357-577
Door/Window Mouldings and Frame, Right Side, 1997 Sedan
Door/Window Mouldings and Frame, Left Side, 1997 Sedan
Sunroof assembly, coupe
Sunroof assembly, sedan
LS speedometer, 86921 miles, 78100-ST7, A820-M1, 157370-2050-002
Complete wiring octopus, 1997 LS sedan
Acura headunit by Pioneer, 39100-ST8-A000, 39101-ST8-A010-M1, KEH-M74362H, PE-17350
Helms service manual
Airbag, black, 2001, HDMC1GD810, Manufactured Jan 01, 77800-ST7V-A710-00
Fender liner, FENDER R FR INN, 74101-ST7-0000
Black tailgate leather cover trim, LNG TAIL GATE, 84431-ST7-0000
Ventilation floor ducts, 83331-SR4-A000 LH
Metal chassis reinforcements, sedan, T8R and T8L
Washer fluid reservoir, with motor, sedan
Engine mount, sedan, 1
Alternator (?), Honda Denso, DXDR6, OB-2280000-3991, 12V-10R25
SRS Computer, 77960-ST7-N91, CDG-17B956
ABS Control Unit, NEC, 39790-ST7-A02
Cruise Control Unit, Mistuba, 36700-ST7-A02, 6004243, P7S-MT
SRS computer cover, L800, 77963-SR3-R, pair, sedan
Fuse box, ST7-A0TZ
Brake fluid reservoir (?), Toyoroki, 90B730, 6T18-S04
High pressure line and brake or clutch cylinder, 80241-ST7-A320 23XH, 80331-ST7-0031 21XH
Hatch, 2001, black, w/ glass, never tinted
Dashboard, black, with wiring and glovebox
Pedals, manual, brake and gas
Power steering fluid reservoir
Bumper porkchop, 71172-ST7-A000, GST FR BPR BEAM
Metal body part, miscellaneous
Cabin fuse box, 38600-ST7-A01-M1, 311443
Silver driver fender with liner, light damage, 74151-ST7-0000
Rear mudflaps, pair
Door, black, coupe, driver side, with handle and glass, light rear edge damage
Fender liner, perfect, L FR INN, 74151-ST7-0000
Silver driver fender, perfect, 74151-ST7-0000
Trunk, silver, w/ LED wing
COVER DR INST LWR MSP, 77311-ST7-A010
Sedan door, passenger, rear, incl handle, silver
Sedan door, passenger, front, light damage, silver
GSR B18C1 Long block w/ axles, cluster, ECU
Airbag, passenger, black, 77850-ST7Y-A910-00, Manufactured Oct 96
LS B18B1 Intake manifold w/ sensors: Denso 136200-1350/PCS7, and Denso 138200-0600/6TA 630
Black leather-wrapped steering wheel
Airbag, steering wheel, black, Acura 94-97 style logo
New OEM air filter
Intake manifold gasket
LS B18B1 distributor
Airbag, steering wheel, black, Honda logo, 77800-SR4-A800
White JDM ITR 4dr spoiler
Floor mats, OEM, black, front pair
Door sill, GARN L SIDE SILL, 4-door, 71850-ST8-0000
Spoiler, OEM GSR, black, needs painting
Taillight, 4-door, passenger side pair, inner 226-22235, outer 220-22235
Steering wheel, black
Washer fluid reservoir, coupe, incl. dual pumps
Approx. 1-1/2” diameter high pressure hose
Approx. 1” diamtere high pressure hose
Honda Denso DXDR6, 228000-3991
Denso, 10PA15C, 447200-1063, 10R4205, HFC134a
Honda Denso 10PA 15C, 447200-1386, 12B 2429, HFC134a, F356062, DC12V12B, 447300-1105
Denso 447200, R134a
Air Conditioning Condensor
Pulley device, miscellaneous, P72-074273S
Cooling fan, PA6-G, 5499/280
ABS fuse box, ST7-B
Speaker, OEM, EAS23D41F, 15w, 4-Ohm
Aftermarket Honda/Acura
ACT Clutch, AI4-HDSS
Clutchmasters Lightweight Flywheel
Neuspeed Rear Lower Tie Bar
MB Quart PSD-216 Frames and Cover Grilles
Fluidyne radiator
McGard locking lug nut set with key
Viper 500HF alarm
Fog lamps
Infinity Reference 6952i 6x9 coaxial speakers
OEM BMW
Double Spoke I wheels, full set, painted black with silver lip, 6/10 condition
2 Roundel wheel centers, 36-131-180-419, 6135800
OEM headlights
Miscellaneous
Aiwa CX-NMT520 Audio System
Desk organizer, black, with halogen lamp, needs bulb
46 gallon Perfecto bowfront glass fish tank with solid pine stand, woodgrain
Yamaha saxophone and accessories, used
Raised dog bowl stand, oak, stained, with dual stainless steel bowls
CaribSea Live Aragonite Sand, Fiji Pink, 8 x 20lbs, #00792
Bucket of saltwater aquarium sand
Bucket of live rock, dried out
PalmPilot Professional, with leather case, serial 106V17588RE4
Clarity Plus acrylic hexagon aquarium, 28 gallon, with repaired crack
AquaClear 300 power filter
AquaClear 500 power filter
Coralife VHO bulbs, actinic, brand new, 3 x 72”
Eheim 2026 canister filter
Eheim 2226 canister filter
Eheim 2213 canister filter
Icecap 660 electronic light ballasts, with wiring and endcaps, needs fuses, 2 ballasts
Nisso dual fluorescent aquarium light strip, 25”, 25w x 2, independent light controls
Live rock, dry, 176 pounds
Either PM me or email me at mr_mbuna (at) yahoo.com to discuss! Motivated seller!
Modified by mr_mbuna at 7:57 PM 1/6/2005
Modified by mr_mbuna at 3:37 PM 1/8/2005
Old Jan 7, 2005 | 02:16 PM
mr_mbuna's Avatar
Default Re: FS: OEM and Aftermarket Acura Integra Parts - Interior, Dash, GSR, Airbags, Speakers, Door Trunk
Old Jan 7, 2005 | 08:18 PM
mr_mbuna's Avatar
Old Jan 7, 2005 | 10:31 PM
spriggan's Avatar
pm sent
Old Jan 7, 2005 | 11:05 PM
Seedc2's Avatar
Default Re: (spriggan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spriggan &raquo;</TD></TR><TR><TD CLASS="quote">pm sent</TD></TR></TABLE>
Old Jan 8, 2005 | 08:34 AM
mr_mbuna's Avatar
Default Re: (sim shadeee)
Old Jan 8, 2005 | 08:44 AM
Vera's Avatar
Default Re: (mr_mbuna)
pmed
Old Jan 8, 2005 | 11:21 AM
mr_mbuna's Avatar
Default Re: (Vera)
Replies sent.
Old Jan 8, 2005 | 01:26 PM
illi Adik's Avatar
Jesus man you might as well sell your soul while you are at it.
Bump.
Old Jan 8, 2005 | 10:47 PM
mr_mbuna's Avatar
Default Re: (Jackson4Door)
Soul for sale - $5,000
Old Jan 9, 2005 | 12:49 PM
EnjoyTheRideDC2's Avatar
Price on the front mats? I NEED these..
Old Jan 9, 2005 | 01:28 PM
jonyb's Avatar
Holy parts list Batman!! That's a lot of stuff
Old Jan 10, 2005 | 11:52 PM
mr_mbuna's Avatar
Let me tell you a story...
Old Jan 12, 2005 | 12:16 PM
mr_mbuna's Avatar
about a lovely lady...
Old Jan 16, 2005 | 10:52 AM
kid-honda's Avatar
You got PM
Old Jan 20, 2005 | 07:43 AM
mr_mbuna's Avatar
who lived in the woods...
Old Jan 20, 2005 | 10:15 AM
mr_mbuna's Avatar
and one day along came a bear...
Old Jan 20, 2005 | 12:13 PM
mr_mbuna's Avatar
and the bear had bigggg teeth...
Old Jan 21, 2005 | 12:46 AM
illi Adik's Avatar
This guy is broke as a joke these days, he quit his job.
Buy his parts.
Old Jan 21, 2005 | 04:11 AM
GhettoR's Avatar
im sent
Old Jan 21, 2005 | 04:44 AM
kay_animation's Avatar
Do you have any of these parts I am looking for?
https://honda-tech.com/zerothread?id=1122405
Old Jan 21, 2005 | 07:51 PM
kid-honda's Avatar
What year are the dashes?
Old Jan 21, 2005 | 08:33 PM
racinjason's Avatar
pmed you
Old Jan 22, 2005 | 08:57 PM
mr_mbuna's Avatar
Kay - sorry, don't have those.
Kid-honda: I don't know the year of the dash, but its in good condition and they're all the same...
Old Jan 23, 2005 | 09:31 AM
mr_mbuna's Avatar
Anyway, back to my story...
