D16 ZC SOHC VTEC Potentials?
Old Jan 6, 2005 | 02:14 PM
DaMmniTz's Avatar
Default D16 ZC SOHC VTEC Potentials?
I'm deciding over a shitload of motors for a swap. At first i wanted the d15b but then i wanted D16 ZC SOHC VTEC. I'm just wondering, What's the potential of this engine capable of handling horsepower at peak performance? Can it get up to 200-340 hp range?
Old Jan 6, 2005 | 02:22 PM
untitled's Avatar
Default Re: D16 ZC SOHC VTEC Potentials? (DaMmniTz)
There have been some stock block 300whp z6's, but its very rare. There are alot more people under 250hp. If you want the cheapest route to 300whp a LS-T might savor your HP needs a little better. Ive had both Z6-t and LS-T. I like the LS-T more obivously. You can check out turbod16.com for some of the potential for this engine. I think this is the best SOHC swap you can do for an EF because of the $/hp... You can get these for cheap and can convert to obd1 for about $500.
d16z6 longblock obd1 = $300
obd1 p28 ecu = $100
Boomslang or Evasive harness = Less than $100
and you get 126hp and capability of buying a cheap used Greddy kit for like $1000.
Iloveyourhonda92
13
Jul 10, 2008 07:15 PM
coquitlamEG
Mar 18, 2006 08:43 AM
ZCpwrdEK
Oct 24, 2005 02:48 PM
Dan GSR
Dec 13, 2004 11:53 AM
