URGENT~~~HELP NEEDED~~~A.S.A.P.~~PLEASE
Old Jan 6, 2005 | 01:24 PM
bustah49's Avatar
Default URGENT~~~HELP NEEDED~~~A.S.A.P.~~PLEASE
ok, i have a 91 civic that is converted to mpfi then converted to obd1. i am getting code 22. i have checked and triple checked the wiring. and the grounds.
i also went to the salvage yard and got to vtec oil pressure switches. but the switches i got are from a honda accord. is there any differance between them or did i buy the rare chance get 2 bad switches?
and it can't be oil pressure, i took the sensor off and started the car and oil blew across the yard about 50 ft.
please help.
Old Jan 6, 2005 | 01:44 PM
Blown90hatcH's Avatar
Default Re: URGENT~~~HELP NEEDED~~~A.S.A.P.~~PLEASE (bustah49)
Have you confirmed that the blue wire goes to D6 on your ecu harness/conversion harness. Then the black wire goes to ground on the pressure switch.
Old Jan 6, 2005 | 03:58 PM
bustah49's Avatar
Default Re: URGENT~~~HELP NEEDED~~~A.S.A.P.~~PLEASE (Blown90hatcH)
i guess.....you made the harness/. lol
i know that the black w/ blue stripe is going to the blue wire and the black wire is grounded at the thermostat housing.
Old Jan 6, 2005 | 04:10 PM
bustah49's Avatar
this is the only code that i have and it is driving me nuckin futz
Old Jan 8, 2005 | 10:43 AM
bustah49's Avatar
any body have any ideas? please help.
Old Jan 8, 2005 | 10:44 AM
bustah49's Avatar
Blown90hatcH said*
at d6 i have a green wire...not blue
Old Jan 8, 2005 | 12:49 PM
Nic's Avatar
Nic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bustah49 &raquo;</TD></TR><TR><TD CLASS="quote">Blown90hatcH said*
at d6 i have a green wire...not blue</TD></TR></TABLE>
search I do not know what goes where but I am sure in the archived section there is info on this
Old Jan 8, 2005 | 12:50 PM
HamiltonRex's Avatar
where does it go?.. Its not rocket science. Make sure you have a wire going from the pressure switch to d6. colour dosent matter.
Old Jan 8, 2005 | 01:08 PM
bustah49's Avatar
Default Re: URGENT~~~HELP NEEDED~~~A.S.A.P.~~PLEASE (HamiltonRex)
rocket science....i bought the harness off of him....i can not get rid of code 22
i have tried 2 other vtec oil pressure switches
Old Jan 8, 2005 | 08:17 PM
What colors are on the pressure switch? Normally it is blue and black. The blue needs to go to the D6 pinout on the OBD1 side. The black needs to be grounded. I am not refering to the subharness wire colors.
Old Jan 9, 2005 | 09:18 AM
bustah49's Avatar
black and black with a blue stripe
Old Jan 9, 2005 | 09:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bustah49 &raquo;</TD></TR><TR><TD CLASS="quote">black and black with a blue stripe</TD></TR></TABLE>
Black/Blue goes to D6. Black to ground.
Old Jan 9, 2005 | 03:25 PM
bustah49's Avatar
that is the way it is wired
hitekper4mance
Oct 9, 2007 08:21 AM
projectegr
Jan 18, 2005 12:32 PM
NobodysHero
Jul 10, 2004 08:10 PM
lightningd
Apr 4, 2003 01:30 PM
