coilover adjustment problems
Old Jan 6, 2005 | 12:18 PM
EMphaticONE's Avatar
Default coilover adjustment problems
what's the proper way of measuring each shock to ensure that they are all lowered correctly/equally?
Old Jan 6, 2005 | 12:20 PM
skip.two's Avatar
Default Re: coilover adjustment problems (pearlblueb16)
use your finger(s).
Old Jan 6, 2005 | 12:26 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: coilover adjustment problems (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">use your finger(s).</TD></TR></TABLE>
...or whip out the tape measurer and measure from the top of the fender down to the ground.
Old Jan 6, 2005 | 12:28 PM
Deemeetree's Avatar
Electrician
Get to a level surface (preferably cement/concrete parking lot).
Use a tape measure.
Measure from bottom of fender to the ground or bottom of fender to the center of the wheel.
or
Do it the easy way and use your fingers.
Old Jan 6, 2005 | 12:44 PM
Inspector Gadget's Avatar
Default Re: (Dimi)
^^^What he said.
I accually cut out a block of wood that fits between the perch on the shock and the bottom of the twisty things on the coilover sleeve.
Old Jan 6, 2005 | 12:57 PM
Judd's Avatar
Default Re: (Inspector Gadget)
check threads on the sleeve
Old Jan 6, 2005 | 02:54 PM
Default Re: (Judd)
thanks for the help guys. by the way, i like your avatar Judd. haha
Takumi Fujiwara
Suspension & Brakes
17
May 10, 2011 06:01 AM
Moejos
Suspension & Brakes
Mar 9, 2009 01:11 PM
kcari
Paint and Body
Oct 5, 2008 12:35 PM
kcari
Honda Civic (2001 - 2005)
10
Feb 12, 2008 05:04 AM
silentdancer
Honda S2000
20
May 31, 2007 03:04 PM
