What sleeves are these ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe »</TD></TR><TR><TD CLASS="quote">Look like Darton's to me.</TD></TR></TABLE>
^^^ What he said!
^^^ What he said!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI »</TD></TR><TR><TD CLASS="quote">
^^^ What he said!</TD></TR></TABLE>
I'm with stupid
I'm with stupid
hmm the only other design i have seen like that would be the aebs but those are machined flat across the top
the other alternative would be the leitner sleeves from canada
They are not Darton's...Darton's MID sleeves have more transfer holes on the exhaust side (9) of the sleeve than the intake side (7) to cool the sleeves better on the hot side of the block. The spacing is also specifically placed to match the head gasket. The sleeves also have holes in each side of the outer flat so you can locate them to make sure that they go in straight. Also on the outer cylinders there are 18 water transfer holes that are staggered to match the head gasket.The sleeves shown are just drilled the same all around The Darton MID design is also patented.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darton Sleeves »</TD></TR><TR><TD CLASS="quote">They are not Darton's...Darton's MID sleeves have more transfer holes on the exhaust side (9) of the sleeve than the intake side (7) to cool the sleeves better on the hot side of the block. The spacing is also specifically placed to match the head gasket. The sleeves also have holes in each side of the outer flat so you can locate them to make sure that they go in straight. Also on the outer cylinders there are 18 water transfer holes that are staggered to match the head gasket.The sleeves shown are just drilled the same all around The Darton MID design is also patented.</TD></TR></TABLE>
Will my sleeves work or will the whole thing blow up ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">yeah they look like GE godzilla sleeves to me</TD></TR></TABLE>
I know a guy that has a b16 block looks just like that. GE.
BTW looks Great!
BTW looks Great!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted93Hatch »</TD></TR><TR><TD CLASS="quote">I've seen them before. I thought it was a company called Az Race & Machine but after searching there website they dont do sleeves.</TD></TR></TABLE>
You sir are right! I know I used to have a block like that, and I'm sorry there is nothing good I can say about AZracemachine. It's not AEBS and its not Darton either, well the sleeves are Darton blanks but they were not installed by Darton.
I have no idea now, but is this what it is???
