D16Y8 or D16Z6 camshaft with D16Y8 block and D16Z6 head !?
Old Jan 6, 2005 | 07:00 AM
turboimports's Avatar
Default D16Y8 or D16Z6 camshaft with D16Y8 block and D16Z6 head !?
Hey all.
I was wondering which camshaft I should use in my setup?
I will be using a D16Y8 block and a D16Z6 head. Engine will be boosted.
I know that wichever camshaft I use, I must use the matching cam gear also.
What about the distributor? Will this affect anything else?
OEM camshaft specs:
D16Y8 camshaft (intake/exhaust):
Advertised Duration 246/230 (Crower website)
Duration @ 0.050'' 208/191
Gross Lift 393/369
D16Z6 camshaft (intake/exhaust):
Advertised Duration 244/228 (Crower website)
Duration @ 0.050'' 208/192
Gross Lift 384/370
http://www.hadamotorsport.com/....html
http://www.knology.net/~jediklc/specs.htm
So what do you all think? Will the D16Y8 camshaft even make enough difference? Maybe 2hp? hehe.
-Lor
Old Jan 6, 2005 | 08:20 AM
civic-4-ges's Avatar
Default Re: D16Y8 or D16Z6 camshaft with D16Y8 block and D16Z6 head !? (turboimports)
Match cam gear with crank pulley...at least if you do not want to mess around with timing
Don't forget to match cam sprockets too
Old Jan 6, 2005 | 09:47 AM
So..would the Y8 camshaft make any difference in the Z6 head?
Old Jan 7, 2005 | 08:10 PM
No one else has any input?
Old Jan 20, 2005 | 02:13 AM
sohcvtec66
Guest
Posts: n/a
Default Re: (turboimports)
jdm d15b vtec camshaft more agressive than both of them
Old Jan 20, 2005 | 04:28 AM
jlacoy82's Avatar
71.192.16.183
Default Re: (sohcvtec66)
Use a camshaft for the d16z, I do believe they are different from the d16y's?
94c1v1cex
Mar 30, 2007 04:52 PM
Usdm1
Mar 31, 2003 05:15 AM
KRiS1
Feb 25, 2002 11:50 AM
