pinging on high compression motor
Old Jan 5, 2005 | 09:20 PM
greenb20's Avatar
Default pinging on high compression motor
sup everyone..i have a b20z block with a gsr head...the block has 12:5 wiesco pistons...i had a problem with pinging...i installed an aem fuel rail and a fuel regulator...it is set at 62....i can still hear the pinging but not as bad...does anybody know what can i do to get rid of this detonation...injectors?fuel pump? if anyone knows please help me...thanks
Old Jan 5, 2005 | 10:05 PM
b16hybridsol's Avatar
Default Re: pinging on high compression motor (greenb20)
bigger injectors, less fuel pressure
Old Jan 6, 2005 | 05:18 AM
DIFFUT'S INC.'s Avatar
Default Re: pinging on high compression motor (b16hybridsol)
hey well i say bring the fpr to 54psi and use better gas .what oct you useing now? and what injectors? whats your timming at ?
Old Jan 6, 2005 | 06:52 AM
VN712's Avatar
Default Re: pinging on high compression motor (DIFFUT'S INC.)
Make sure your timing is correct. Use better gas and upgrade bigger injector.
Old Jan 6, 2005 | 03:30 PM
aj99si's Avatar
Default Re: pinging on high compression motor (B20ZLS)
2 liters need a lot of fuel. I would get some 370cc injectors.
lucava05
Jan 29, 2010 08:42 PM
Ruben19
Mar 10, 2006 03:23 AM
phantom_sol
Jan 22, 2004 11:50 PM
RTW DC2R
May 24, 2002 06:54 AM
baonest
Aug 5, 2001 02:51 PM
