clutch help please!
well i go to try to drive the crx for the first time with the "newer" trans. the problem is when i push the clutch pedal all the way to the floor then clutch dose not disengaged, so i can't select gears and what not... when the car is off i can go through the gears just fine and what not. i tried to adj. the clutch cable a billion times at least. hell i made the clutch cable tight enough so the teeth on the pressure plate would have been pushed in and even then still the clutch stays engaged.. so i put the front of the car up on jack stands and start it up.. it goes threw the gears and watched the speedo move up. i have a b18a swap with a act pro-light flywheel and a act 6 puck clutch with a 6000 mile stock pressure plate. 2 of my friends told me the clutch didn't disengage because i am using a 90 pressure plate on a 93 trans.... bahh i am annoyed, can anyone give me some info on whats going on i am stumped... please help
thanx dustin!
thanx dustin!
