Suspension & Brakes Theory, alignment, spring rates....
5-bolt suspension questions
Old Jan 5, 2005 | 06:18 PM
B16A1-EF9's Avatar
Default 5-bolt suspension questions
Hopefully this is in the right forum.
I have an 89 Civic and I want to convert it to 5-bolt. I've heard many different opinions on how to go about this. I've searched and found nothing but alot of maybes.
What I got so far is that the rear trailing arms will fit using my civic's lower and upper control arms. The parking brake cables would have to be the ones from the 90-91 CRX si.
Now the front is where it's puzzling me. Some say to use the complete assembly including the front knuckles and others say to get 91 4-door EX knuckles and get the type r spindles machined to fit in the 91 EX bearings??????
WHICH TO USE?
Does anyone have any detailed info on this setup? Which brake booster and master should I use, the type r stuff wont fit perfect, I'll have to drill correct???
In advance thanks guys.
Old Jan 6, 2005 | 03:19 PM
B16A1-EF9's Avatar
bump...
Old Jan 6, 2005 | 03:46 PM
Lo-Buck EF's Avatar
Default Re: (B16A1-EF9)
use the 91 ex knuckles with 5 lug hubs, itr rotors and calipers. you will get a better fit. the integra knuckles have slightly differant demensions.
-spenc
Old Jan 6, 2005 | 05:06 PM
.RJ's Avatar
.RJ
Default Re: (Lo-Buck EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote"> the integra knuckles have slightly differant demensions.
-spenc</TD></TR></TABLE>
Yep, and will leave you with less available suspension travel
Old Jan 6, 2005 | 06:08 PM
Lo-Buck EF's Avatar
Default Re: (.RJ)
yea, and the last thing a honda needs in front is *less* suspension travel. the ex knuckels are slightly harder to find, but check out http://www.car-part.com for them.
does anyone know what exactly is the differance between the ex and all the other 4g civic knuckles?
-spenc
BigGreenAuto
Nov 20, 2006 10:08 PM
z6_EF_obd1
20
Jun 13, 2006 08:04 AM
tvrsir
13
Oct 29, 2004 04:30 PM
crxcrazy
Jul 16, 2004 10:03 PM
Chris
Oct 16, 2002 04:19 AM
