94 civic ignition problem
Old Jan 5, 2005 | 05:35 PM
kipp's Avatar
Default 94 civic ignition problem
my friend has a 94 civic ex with a d16z6 motor. couple days ago we had a problem with it not starting. it would crank, but not fire. we replaced the distributor cap and rotor and it worked fine. next day, the car would idle almost to dead, but wouldn't die and there seemed to be a lack of power when excellerating. we replaced the spark plug wires are it started right up, but then just died a couple minutes later and we could not get it to start again (crank, but woulnd't fire). In my opinion it's either the timing is off or a fuel problem (injectors or fuel filter). does anyone have any ideas on what this might be and how to fix it. thanx
Old Jan 5, 2005 | 06:02 PM
2lua's Avatar
Default Re: 94 civic ignition problem (kipp)
did you check fuel system? fuel pump, fuel pressure regulator, injectors... ect
Old Jan 5, 2005 | 07:45 PM
kipp's Avatar
Default Re: 94 civic ignition problem (2lua)
that's what we're plannin on checkin tomorrow
Old Jan 5, 2005 | 07:48 PM
ABK's Avatar
ABK
Any CELs?
Check your spark see if it's there, if not either a bad coil, ingnitor or wiring. Also check your fuel and timing.
Old Jan 5, 2005 | 10:52 PM
nxstrikerxn's Avatar
go check ur alternator n ur battery for bad ground cuz i have the same similar problem but mine was a bad ground not starter or alternator if u have ca$h den try to bring it to the shop n see if they say over 200 to fix den 4get it under 200 ok
Old Jan 6, 2005 | 08:47 AM
StoneGold's Avatar
Check things in this order for ease and cost.
Batter for voltage and good ground
Make sure the distributor is set right. And spark is "equal" at all plugs
Alternator for proper output and ground
Fuel filter, at rail (injectors) this will give u an idea about how well the pump is working also, etc
gigigirrl
10
Mar 19, 2021 08:27 PM
mniPeter
May 24, 2015 05:51 AM
Chaze*R
Aug 30, 2005 01:40 PM
civicspeed77
May 27, 2003 12:13 PM
civicwagonman
Nov 30, 2002 11:15 AM
