Canister Valve
Old Jan 5, 2005 | 03:08 PM
C_H_A_D's Avatar
Default Canister Valve
My car was serviced by a Honda dealership and the check engine light was on and the mechanic said because it was a bad canister valve? What is that. My steering wheel shakes when I brake I told them to check my front rotors and pads, They called me and said my rotors were fine but my I need new pads the steering wheel shaking was coming from the rear rotors? I am confused
Old Jan 5, 2005 | 04:06 PM
SlammedAccord96's Avatar
Default Re: Canister Valve (VTECJedi)
About the shaking when you brake, sounds like one or more of the rotors needs to be resurfaced or replaced. Sorry can't help ya with the canister valve thing tho. Good luck, and id take it over to a tire/brake specialty shop for the brake issues.
Old Jan 5, 2005 | 05:52 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECJedi &raquo;</TD></TR><TR><TD CLASS="quote">My car was serviced by a Honda dealership and the check engine light was on and the mechanic said because it was a bad canister valve? What is that. </TD></TR></TABLE>
Canister vent shut valve? The ECU closes it to perform tests to see if there are any leaks in the fuel tank and evap system.
sreine
Sep 6, 2013 09:15 AM
silverxcivic
Jan 28, 2006 03:26 AM
james p.
13
Jun 5, 2005 08:17 AM
bren1339
16
Oct 15, 2003 01:08 PM
RacerXintegra2k
Sep 25, 2002 05:03 PM
