DupliColor paint for Valve Cover...is it good?
Old Jan 5, 2005 | 02:24 PM
1JDMDOMINICAN's Avatar
Default DupliColor paint for Valve Cover...is it good?
I'm painting the valve cover for my B18C and I was wondering if I could use the DupliColor paint line to paint the vc? I went to my local Auto Zone and Pep Boys and there's not much of a good selection of colors to choose from when using high-temp paint, so I was wondering if the DupliColor touch-up paint line is good for valve covers?
I plan to use a high-temp primer if possible and a high-temp clear coat if possible also, but the paint is what I'm worried about most. Don't want it to fade or peel. I also don't want the wrinkle paint thing either......want it to look like if it was powder coated...hehehehe!
What other paint line can yall recommend?
Yes, I know, should've done a search and I did, but the results still did not answer my question....Besides, I've noticed that Dupli Color has a very big selection of colors.
Old Jan 5, 2005 | 02:29 PM
.ShawnD.'s Avatar
any paint works.. the valve cover doesnt get hot enough to "melt" the paint .. even with a high heat primer .. i use etiching primer works well to help the paint come out 200x's better .. check sig
lilboxx
36
Apr 14, 2012 09:45 PM
mitsuman
Apr 17, 2010 11:55 AM
adamisgreat88
17
Jun 8, 2009 02:52 PM
wrinkles
Mar 19, 2006 03:33 PM
uses0ap
Mar 15, 2006 07:37 PM
