Have a problem .... can somsone help
Old Jan 5, 2005 | 01:39 PM
NeRdY's Avatar
Default Have a problem .... can somsone help
Sup all, i got a 2 door 2000 gsr and i recently brought it to a tinting place near my house to get the bak 3 windows done...when i went to pik it up i seen the bak of my window on the hatch, the top portion wasnt tinted, i was told that they cant do it on the top of the window on the hatch, becuase of these little black dots called "Matrix bumps", was wondering if anyone else has this problem n how did u fix it, was told i can get a layer of black vinyl out there, but pleees help dont want my window to look like crap... Thanx..
Old Jan 5, 2005 | 01:43 PM
xb.oWler's Avatar
Default Re: Have a problem .... can somsone help (18 Visions)
hmm. i dont really have a suggestion but those bumps would probably be pretty hard to cover up, i would think you'd get nasty air holes in the tint which would probably end up lookin worse,
im not gonna get my my tegs windows tinted, but my old cars were, i dont think it had the bumps tho.
Old Jan 5, 2005 | 02:20 PM
eric8876's Avatar
Default Re: Have a problem .... can somsone help (F)
Ya it's true they did it on my car and where the bumps are it looks like **** i wish i just told them to leave that portion untinted
Old Jan 5, 2005 | 02:32 PM
dokesdc2's Avatar
I have a '00 hatch too, with tinted windows. The place I took it to just covered up the dotted area with the tint. It looks kinda lame because the tint can't stick to the glass because of the dots (but it'll stick to the dots, so it doesn't peel off or anything), but you get used to it, and I think it looks ok. The place told me that it looks better than not tinting it, esp from the inside. The finish is pretty uniform, I don't have streaks or spots where it sticks to the glass and some where it doesn't. I'm satisfied.
Old Jan 5, 2005 | 02:51 PM
phenom3030's Avatar
Default Re: Have a problem .... can somsone help (dokesdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dokesdc2 &raquo;</TD></TR><TR><TD CLASS="quote">I have a '00 hatch too, with tinted windows. The place I took it to just covered up the dotted area with the tint. It looks kinda lame because the tint can't stick to the glass because of the dots (but it'll stick to the dots, so it doesn't peel off or anything), but you get used to it, and I think it looks ok. The place told me that it looks better than not tinting it, esp from the inside. The finish is pretty uniform, I don't have streaks or spots where it sticks to the glass and some where it doesn't. I'm satisfied.</TD></TR></TABLE>
I agree with you. I've got an 01 hatch and my dots are tinted too. Up close it does look a bit bad but you'll get over it. The shop that did mine said to just continue to squeegee it the days after my car was tinted to get as much air out as possible. I managed to do a bit the day after but forgot to keep doing it so i'm stuck with it partially not sticking. oh well. I personally think it looks okay, you don't really see it unless you go up to it and look for it.
I also think it looks better than not tinting it. I've been in a friends car w/o tinted dots; at night you've got this band of light shining through an otherwise dark car. That bugs me more than not having the dots tinted. Other than that, I'm satisfied.
Old Jan 5, 2005 | 09:19 PM
b-power's Avatar
Default Re: Have a problem .... can somsone help (phenom3030)
every now and then you get one that lays down perfect. it took three attempts to get mine down perfect, but my tinter finally got it. luckily i work with him, so it didnt cost me as much
Old Jan 5, 2005 | 10:39 PM
ShortBusTechnologies's Avatar
Default Re: Have a problem .... can somsone help (b-power)
Got mine done and the same things going on. Looks like ****. But you have to look close to see them. They tinted all the way up. No biggie. Hardly notice it.
Old Jan 5, 2005 | 10:42 PM
ICEwoMANhOTTiE's Avatar
i have the same problem......my tint job is so0o shittyyyyy.....It looks horrible but I dont want to have to pay to get it taken off and then redone again because they told me it was almost impossible to have it layed down perfectly....but when I see other people's hatch glass that is tinted, its the same thing
Old Jan 5, 2005 | 10:43 PM
calxtreme's Avatar
if you really wanna get rid of the dots, can't you use some kind of solvent like paint thinner or something, then you would be able to get tint on there smooth? just my $0.02
Old Jan 5, 2005 | 10:47 PM
Dres's Avatar
here you go this should help you decide what you want to do.
http://www.team-integra.net/se...D=534
Old Jan 5, 2005 | 11:01 PM
Sack Master's Avatar
Default Re: Have a problem .... can somsone help (Dres)
I have black vinyl on my upper portion. I think it looks clean.
Old Jan 5, 2005 | 11:38 PM
NeRdY's Avatar
Default Re: Have a problem .... can somsone help (Sack Master)
Any of you got a pic of ur bak window, wit the vinyl on it, gunna go bak tommorow to see what they can do to help it...
Old Jan 6, 2005 | 12:38 AM
Old Jan 6, 2005 | 09:18 AM
NeRdY's Avatar
nice...what i meant to say was does anyone have a pic of there car wit tint, n a vinyl on the top, jus wanna see if the vinyl will flush with the tint...
Dohc 4door Rye
Nov 11, 2006 03:34 PM
soon2bdropped
May 27, 2006 09:21 AM
AznImage504
Sep 17, 2004 05:16 PM
seer_claw
Jan 31, 2004 01:53 PM
Yogi bear
Oct 21, 2001 04:19 PM
