what will bolt into a 85 crx si
Old Jan 5, 2005 | 01:10 PM
SpankyofNOLA's Avatar
Default what will bolt into a 85 crx si
what engines will bolt directly into a 85 crx si
and what engines can fit into my car but will need mounts from other types of cars?
thx thx
Old Jan 5, 2005 | 01:12 PM
JDN169's Avatar
Default Re: what will bolt into a 85 crx si (SpankyofNOLA)
85 Si's kick ***!!!
1g integra motors bolt in.
B16 with impossible to find hasport mounts.
Old Jan 5, 2005 | 01:13 PM
EFB16ACRX
Guest
Posts: n/a
Default Re: what will bolt into a 85 crx si (JDN169)
http://www.redpepperracing.com is your friend
Old Jan 5, 2005 | 01:29 PM
CRX T-Si's Avatar
Default Re: what will bolt into a 85 crx si (90HFB16B)
RPI RACING did this one.
http://www.rpiracing.com/RPI_P...t.htm
Old Jan 5, 2005 | 01:42 PM
Kwicko's Avatar
Default Re: what will bolt into a 85 crx si (CRX T-Si)
Yup, the '86-'87 Integra motor should drop right in. It's generally considered easier to use the '86 & '87 'Teg engines because they use the same vacuum-advance system for the distributor timing, where the '88-'89s went to an electronic advance. You *can* use the '88-'89, but it's supposed to be a bit more work and wiring to figure out.
'85 Si's rock. The first Si Honda ever sold (in the US, anyway), and the lightest, by a bunch!
Mike
Little_Nolan
Classic Hondas
Sep 16, 2009 01:28 AM
johnny hatchback
Sep 1, 2004 08:20 AM
didyouhearthat
Jun 19, 2003 03:50 PM
hecktabite
Jan 14, 2003 10:24 PM
srollo
32
Apr 6, 2002 10:55 AM
