Sway bars????
Old Jan 5, 2005 | 12:23 PM
hondacivic4g's Avatar
Default Sway bars????
I've searched and found nothing that tells me if the 4 door sway bars will fit on a HB?
If so then what sizes are they?
Also does anyone have the sizes for all models of Civic and CRX? I found so many different #'s that i'm not sure what the sizes really are, if anyone has them please post.
Thanks-Jason
Old Jan 5, 2005 | 08:25 PM
Default Re: Sway bars???? (hondacivic4g)
ttt
Old Jan 5, 2005 | 10:19 PM
XrcR6's Avatar
It will fit there isn't any difference, they're all bent the same way...just different bar thicknesses. To the best of my knowledge, I believe it goes something like this for USDM 88-91 ED's:
Civic 4Dr:
19mm front, no rear
Civic Wagon:
19mm front, no rear
CRX HF:
17mm front (hollow and actually ~17.3mm according to bushing stamping), no rear
CRX Si/Civic Si:
18mm front, 15mm rear
All other Civic hatch (STD & DX) and CRX (DX) models:
18 front, no rear
Also you can use DA Integra sway bars with the ED/EF.
22mm front (this might be hollow), 14.7mm/15.9mm (coupe/4dr sedan) rear
When interchanging the front you just need the bar and corresponding bushing, all the other brackets and endlinks are the same. For the rear, if your car didn't come with a sway bar, you'll need to figure something out and that's been covered before. A search should reveal some creative suggestions.
Old Jan 5, 2005 | 11:35 PM
Default Re: Sway bars???? (XrcR6)
I searched and read 90%+of the threads on the sway bar(s)subject of the EF/ED models. All I read said nothing of the Sedans bars.
Thanks for the info cool.
Old Jan 6, 2005 | 08:13 PM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XrcR6 &raquo;</TD></TR><TR><TD CLASS="quote">All other Civic hatch (STD & DX) and CRX (DX) models:
18 front, no rear</TD></TR></TABLE>
Accually Civic STD has no front or rear (at least my 91 didn't)
____________
Old Jan 6, 2005 | 09:56 PM
XrcR6's Avatar
Default Re: Sway bars???? (Louie B.)
You're probably right on that Louie, my STD vs DX knowledge is gray. I've seen them in the boneyards with front bars and sometimes its hard to tell what model they started life as, other than not-an-Si. I just lumped them all together.
I guess for hondacivic4g the gist of it is there are 19, 18, and 17(hollow) front bars from the factory that will fit. Given enough time you should be able find each in a junkyard, but you should take a vernier caliper to be sure (I do). Or ask the guy you are buying them from to measure it or read the stamped # on the bushing (if he has it).
For the rear, it should be the same deal for any 4th gen ED. Get the rear LCA with the threaded holes for the endlinks, if you don't have them already. Then figure out a way to mount the L-bracket to the unibody, since you probably have holes without the threaded nut to bolt them to.
mynameizstitch
Jul 22, 2012 10:44 AM
rybred
29
Apr 15, 2012 11:31 AM
masterEF
Suspension & Brakes
Jan 4, 2010 01:22 PM
tysf
Aug 19, 2003 08:41 PM
Eric J
Aug 11, 2002 06:26 AM
