adjusting FPR with engine on or off? noob question.
Old Jan 5, 2005 | 11:54 AM
1.8's Avatar
1.8
Default adjusting FPR with engine on or off? noob question.
i'm thinking it's suppose to be on. but just want to double check. thanks.
and at idle, an LS motor should be around 40 psi, right?
Old Jan 5, 2005 | 12:00 PM
hayabusa160's Avatar
Default Re: adjusting FPR with engine on or off? noob question. (1.8)
yes the motor has to be on
Old Jan 5, 2005 | 12:01 PM
1.8's Avatar
1.8
Default Re: adjusting FPR with engine on or off? noob question. (hayabusa160)
thanks. also do i have to take off the vacuum line and cap it off? and a LS should be at 40 psi?
Old Jan 5, 2005 | 12:06 PM
mitsuman's Avatar
stock is around 40 yes. you can either take the vaccum line off, tighten the screw, then put the line back on, or tighten the screw with the line on. when you take the line off the fuel pressure will go up a bit, but dont worry it will come back down as soon as you re-attach it.
Old Jan 5, 2005 | 12:10 PM
1.8's Avatar
1.8
Default Re: adjusting FPR with engine on or off? noob question. (mitsuman)
when the line is off, are you suppose to cap off the FPR? or just leave it open?
Old Jan 5, 2005 | 12:20 PM
DaX's Avatar
DaX
Loved
Community Favorite
To test static fuel pressure:
Attach a fuel pressure gauge.
Remove the vacuum line from the FPR and place your thumb over it to prevent a vacuum leak.
Read the gauge.
B_Swapped93
Mar 25, 2013 10:35 AM
typeeg
Jun 16, 2004 07:01 PM
UNVMYR
Dec 23, 2002 03:07 PM
Popkorn
Nov 25, 2002 11:43 PM
Greyout
May 26, 2002 05:13 PM
