replacement parts for jdm type r five lug?
Old Jan 5, 2005 | 09:52 AM
hondaeg5's Avatar
Default replacement parts for jdm type r five lug?
the car we are building right now was in a accident and it has damage to the l/r trailing arm(bent) looking for a replacement-will any trailing arm do? i remember something about the jdm type r five lug having different diameter axles,but dont know if thats the only difference.
thanks
chris
Old Jan 5, 2005 | 10:16 AM
Ricey McRicerton's Avatar
Default Re: replacement parts for jdm type r five lug? (hondaeg5)
You can replace all of the stuff on your car with USDM 5 lug ITR brake parts. If you got them onto your car, you don't have the brakes with the larger 36mm hubs.
Old Jan 5, 2005 | 10:22 AM
jdmjade's Avatar
That would be the only difference. The JDM 5-Lug has a more spline on the axle end goes into the steering knuckle.
Old Jan 5, 2005 | 10:24 AM
hondaeg5's Avatar
Default Re: replacement parts for jdm type r five lug? (jdmjade)
it has the larger axels already. so everything else is the same as usdm except axels correct?
iwannarace
Sep 10, 2014 08:51 PM
DB8ITR
May 19, 2009 10:33 AM
Vl4d
May 22, 2007 11:19 AM
vteckiller1.8
17
Sep 26, 2005 09:36 PM
integraownsyou
Nov 23, 2003 09:53 PM
