What springs for my H22a ?
Old Jan 5, 2005 | 06:45 AM
NY93CivicEx's Avatar
Default What springs for my H22a ?
I have a H22a motor going into my 93 civic ex coupe. I have Eibach springs, 1.8 in the back, 1.6 in the front i believe.. but i know im going to need higher rated springs (or atleast i believe so) when i do the swap, to counter balance the engine's 'forward' weight.
What spring rates do i need? front and back.. to try and eliminate the balance
also... should i replace struts/shocks? i have kyb struts for the springs i currently have, but i'm not familiar at all with suspensions, and i'd really appreciate any info about what setup would preform best for me.
thanks
Old Jan 5, 2005 | 08:31 AM
PABLOHONDA's Avatar
Default Re: What springs for my H22a ? (NY93CivicEx)
i know that there are more companys out there that make springs besides eibach that are make for cars w/ swaps.
Old Jan 5, 2005 | 09:37 AM
spyderracing's Avatar
Default Re: What springs for my H22a ? (PABLOHONDA)
It's more a case of what you plan on doing with the car as opposed to what engine you have. Sure the h22 is heavier and you will need higher spring rates up front, but the pairing of front and back will depend on what you want to do (roadrace/autox, drag, etc.).
Edgar Mojica
Suspension & Brakes
Feb 28, 2017 07:02 PM
661rex89si
Suspension & Brakes
Aug 14, 2010 08:16 PM
Rease3
Mar 21, 2010 04:23 PM
Rancid_949
Suspension & Brakes
Dec 6, 2005 03:41 PM
