Idle adjust on C20AT (V6 2.0 turbo) engine
Hi folks.
I've got an '89 Legend Ti which is fittted with the standard 2 litre V6 turbo engine. Everything runs fine, no codes on the ECU but the idle is high (~1500rpm). I thought this would be easy enough to solve... idle air screw and yellow LED on the ECU. Not so! I can't even FIND the idle air screw, let alone twiddle the thing. I've looked all round the throttle body and I'm damned if I can see it.
So, anyone have any idea where the idle air screw is or, if that's inappropriate, how you do adjust the tick over on one of these beasties?
Thanks for your help.
Simon
Simon
jdm.ejone
Jun 15, 2008 04:50 PM
