Need Help Please d15b2 With studdering problems :/
Old Jan 5, 2005 | 12:47 AM
Schaz's Avatar
Default Need Help Please d15b2 With studdering problems :/
okay i just replaced all my valves (intake and exhaust) on my motor...ended up having on my #2 Cylinder 1/2 of the valve head broke off before i bought the car....i cant see to find out what it is but from lookin from the top of the motor there is a a place to plug in a vaccum line idk what its called but i think the like goes to the crankcase? this is what my friend told me..i was wondering if with this being clogged...its right on my fuel intake where it separates into 4...i was wonderin if this would make it choke...
i was wondering if anyone had a picture of the DPFI intake manifold so ppl could see what im talkin about
thanks!!
Greg
Old Jan 5, 2005 | 05:23 AM
DaX's Avatar
DaX
Loved
Community Favorite
Old Jan 5, 2005 | 05:55 AM
Schaz's Avatar
Default Re: (DaX)
yes its that V on the 2nd Intake port what the hell is it and would it cause my car to choke and sputter?
Old Jan 5, 2005 | 05:57 AM
DaX's Avatar
DaX
Loved
Community Favorite
That is your PCV valve. The valve screws into the IM and the hose runs from the valve to the black box on the back of the engine. The purpose of the PCV system is to evacuate oil vapors from the crank case. Not sure if this is your problem or not.
Old Jan 5, 2005 | 06:00 AM
Schaz's Avatar
Default Re: (DaX)
well i just did a valve job...and now the throttle surges like goes from idle to 1.5-2k+ then back down then eventually stalls out...i dont know where to start
Old Jan 5, 2005 | 06:13 AM
DaX's Avatar
DaX
Loved
Community Favorite
Check for vacuum leaks. Did you remove the IM from the head when doing the valve job? Is it possible you don't have a good seal between the head and IM?
Old Jan 5, 2005 | 06:22 AM
Schaz's Avatar
Default Re: (DaX)
i will check that...it was late at night and no place was open to buy a gasket for it...so we used...RTV gasket
Old Jan 5, 2005 | 06:26 AM
DaX's Avatar
DaX
Loved
Community Favorite
I think we may have found your problem.
Old Jan 6, 2005 | 06:31 AM
Schaz's Avatar
Default Re: (DaX)
thanks...i went out andbought the intake manifold gasket and it works!! :D now all i need to know is how to Do the ignition timing..i think we got it right but isnt it supposed to be at 18 degrees for a d15b2? and if so yeah someone explain it to me thanks :D
ryanangelo212
Mar 20, 2013 12:09 PM
wasapyt
Jul 20, 2010 03:37 AM
SuM Honda
Feb 11, 2009 05:32 PM
sick_dc2
Nov 22, 2008 01:33 AM
alotawatts
Nov 5, 2004 11:20 AM
