Wire Tuck Write-up (searched)
Old Jan 4, 2005 | 11:11 PM
BoostedJeff's Avatar
Default Wire Tuck Write-up (searched)
I was wonderin if anyone has posted a write up with pictures on exactly how to do a good wire tuck?
I searched but didn't come up with anything.
Thanks in advance
Old Jan 4, 2005 | 11:16 PM
Dforce's Avatar
That's what she said!
Default Re: Wire Tuck Write-up (BoostedJeff)
cuz i wanna know too.
Old Jan 4, 2005 | 11:23 PM
Default Re: Wire Tuck Write-up (Dforce)
BUMP, i wanna do a wire tuck sooo bad
Old Jan 4, 2005 | 11:25 PM
WhiteSlips's Avatar
Pick all the wires you think need to be tucked and tuck them in places less noticeable. It's just common sense to me and it really isn't hard once you get in to it. Just have zip ties and 18 gauge wire and solder ready to go.
This is a friend of mine's crx that i did a lot of the work on.
Old Jan 4, 2005 | 11:32 PM
mrdanglez's Avatar
Default Re: Wire Tuck Write-up (crstfr14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crstfr14 &raquo;</TD></TR><TR><TD CLASS="quote">Pick all the wires you think need to be tucked and tuck them in places less noticeable. It's just common sense to me and it really isn't hard once you get in to it. Just have zip ties and 18 gauge wire and solder ready to go.
Looks great, how long it take u to do that???
Old Jan 4, 2005 | 11:34 PM
JL's Avatar
JL
dang that looks good!! im thinking maybe he wants to know whats up with cutting the frame for the wires to go through..? thats the only method i've seen, turns out great.. i'd like to completely remove all my brake lines from the firewall and do them "under the dash" i think it would look a lot better.
Old Jan 4, 2005 | 11:37 PM
Default Re: Wire Tuck Write-up (mrdanglez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdanglez &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jan 4, 2005 | 11:38 PM
WhiteSlips's Avatar
Default Re: Wire Tuck Write-up (JL)
All we did was extend the headlight harness about 6 wires on each side and ran them down the firewall and in to the fender well attaching then to the side with zip ties. The fuse box was moved from the strut tower to the firewall, but should've been moved under the dash. We also ran the main wiring harnesses for the motor under the fender liner and just extended the wires that had to be extended for it to reach.
WhiteSlips's Avatar
about 200 hours
Old Jan 4, 2005 | 11:42 PM
WhiteSlips's Avatar
My car
Before
After
Soon I'll have a dry cell battery under the dash and the fuse box under the dash
Modified by crstfr14 at 5:25 PM 1/5/2005
Modified by crstfr14 at 5:29 PM 1/5/2005
Old Jan 4, 2005 | 11:45 PM
t-blizzard's Avatar
crstfr14 is right about it being pretty much common sense, just cut and extend wires. that is basically it in a nut shell, hide wiring under fender liner or any place that is secure and hidden.
mrdanglez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crstfr14 &raquo;</TD></TR><TR><TD CLASS="quote">about 200 hours </TD></TR></TABLE>
but worth it
spriggan's Avatar
You Can eat off that muthfuker...Good job, its hella clean
Old Jan 4, 2005 | 11:48 PM
WhiteSlips's Avatar
Default Re: Wire Tuck Write-up (spriggan)
It's worth the effort when your all done that's for sure. Also Hondas have a lot of useless brackets for wiring and sensors that if you deplete those then you will be able to make the moving and tidying up a lot easier.
Old Jan 5, 2005 | 12:04 AM
WhiteSlips's Avatar
bump for my favorite topic
Old Jan 5, 2005 | 12:57 AM
jeiden's Avatar
nice
Old Jan 5, 2005 | 01:53 AM
2.2XDreams's Avatar
Default Re: Wire Tuck Write-up (jeiden)
wow, those engine bays look so clean with those wires tucked away.
Old Jan 5, 2005 | 02:21 AM
Mr.OB*GYN_Rhett's Avatar
Default Re: Wire Tuck Write-up (2.2XDreams)
so clean
Old Jan 5, 2005 | 02:28 AM
manekDC2.'s Avatar
Default Re: Wire Tuck Write-up (EkNineSpooner)
some nice bays.. great info
Old Jan 5, 2005 | 05:21 AM
AGB5901's Avatar
ive also heard that shops can do it for a small charge...if your too lazy to do it yourself
Old Jan 5, 2005 | 06:01 AM
bbarbulo's Avatar
200 hours of work isn't a "small charge" as you put it
Old Jan 5, 2005 | 07:31 AM
EJ8Joel's Avatar
Default Re: (bbarbulo)
In an EK, do you guys relocate the engine bay fuse box, or keep it, and clean up the engine harness and accs. harness? I cleaned up mine a little last summer, but not to this extent. Looks real nice.
Old Jan 5, 2005 | 07:34 AM
ek four's Avatar
Default Re: (JDMJoelEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJoelEK &raquo;</TD></TR><TR><TD CLASS="quote">... relocate fuse box...</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1096850
Old Jan 5, 2005 | 08:20 AM
EJ8Joel's Avatar
Default Re: (ek four)
Nice ride, but i cant really see the engine bay very well. Do you have any other pics, or recomendations?
Old Jan 5, 2005 | 08:21 AM
AnToNy's Avatar
JDMlifestyle did one in the EG forum. Look there.
