will i need a camber kit
Old Jan 4, 2005 | 11:04 PM
MSP's Avatar
MSP
Default will i need a camber kit
hey i'm about to lower my car about 2 inches and i was wondering will i jus need a camber kit for the front or the rear also?
Old Jan 4, 2005 | 11:14 PM
adio's Avatar
Default Re: will i need a camber kit (urkel19)
hondas are not straight line cars, so if your tires start balding on the insides, you aren't really driving.
Old Jan 4, 2005 | 11:41 PM
accordselux's Avatar
Me Gusta History
Default Re: will i need a camber kit (adio)
2" or lower and you'll want a camber kit
Old Jan 5, 2005 | 08:17 AM
ImportAutoPerformance.com's Avatar
You will definitely need a camber kit. Contact me and I will explain your options.
Old Jan 5, 2005 | 09:48 AM
Drywater2005's Avatar
1 inch or more an you need camber unless you like to change your tires every 6 month... you really only need the kit for the front... any good alighnment center can fix the rear easy on front wheel drive cars
Old Jan 5, 2005 | 10:38 AM
Me Gusta History
Default Re: (Drywater2005)
Not really, I have 1.25" drop all around. You only need a camber kit 2" and lower.
Old Jan 5, 2005 | 10:50 AM
.bagged's Avatar
Default Re: will i need a camber kit (accordselux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux &raquo;</TD></TR><TR><TD CLASS="quote">2" or lower and you'll want a camber kit</TD></TR></TABLE>
Rule of thumb is usually 2"
Old Jan 5, 2005 | 11:30 AM
sj993's Avatar
Default Re: will i need a camber kit (bagged93accord)
2" or lower you will need one and as said above probably just the front.
Old Jan 9, 2005 | 05:51 PM
integraracer92's Avatar
you dont need a camber kit, and for the back...use washers and save some $$. get a good alignment by someone that knows what their doing and you'll be fine. i have my integra dropped about 3 with very little...and i mean little tire wear with no camber kit, but thats me
Old Jan 9, 2005 | 05:53 PM
fw190bvi's Avatar
Default Re: will i need a camber kit (integraracer92)
i have sportlines (1.9") and no camber kit.....
Old Jan 9, 2005 | 05:55 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drywater2005 &raquo;</TD></TR><TR><TD CLASS="quote">1 inch or more an you need camber unless you like to change your tires every 6 month... </TD></TR></TABLE>
Yeah, if you drive about 50,000 miles during that time period.
Old Jan 9, 2005 | 05:59 PM
fw190bvi's Avatar
Default Re: will i need a camber kit (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">i have sportlines (1.9") and no camber kit..... </TD></TR></TABLE>
i might add i drive about 8k a year, and rock yoko avid tourers
Old Jan 10, 2005 | 07:02 PM
Cory Matthews's Avatar
bent your spindles?
Old Jan 10, 2005 | 07:37 PM
iam7head's Avatar
Default Re: will i need a camber kit (b20zej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20zej1 &raquo;</TD></TR><TR><TD CLASS="quote">bent your spindles?</TD></TR></TABLE>
worthless comment
use washer shims in the rear if you have anything before 6th gen accord
Old Jan 10, 2005 | 08:02 PM
Default Re: will i need a camber kit (iam7head)
you've never heard of bending your spindles? no you havent huh. then stfu
Old Jan 10, 2005 | 08:04 PM
cyb3rjak's Avatar
im planning to also drop mine another inch or so. Anyone suggesting getting it alined afterwards?
Old Jan 12, 2005 | 01:18 PM
yellowdcn's Avatar
Default Re: will i need a camber kit (cyb3rjak)
yes or no question i just installed my eibach sportline on my accord and will i need them?
Old Jan 12, 2005 | 01:28 PM
sj993's Avatar
Default Re: will i need a camber kit (yellowdcn)
I don't remember how much sportlines lower, but if it's 2" or more than yes, you will.
Old Jan 12, 2005 | 01:45 PM
yellowdcn's Avatar
Default Re: will i need a camber kit (sj993)
its almost 2 in but not quite that low will i still need them just in case or maybe in teh future?
Old Jan 12, 2005 | 02:33 PM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowdcn &raquo;</TD></TR><TR><TD CLASS="quote">its almost 2 in but not quite that low will i still need them just in case or maybe in teh future?</TD></TR></TABLE>
You will be just fine.
Just make sure to rotate your tires as normal and you will be ok.
Old Jan 12, 2005 | 04:57 PM
yellowdcn's Avatar
when should i rotate my tires?
Old Jan 12, 2005 | 05:03 PM
sj993's Avatar
I do mine every 3000 miles along with my oil change. I think normal rotation is 5000 or 7500 miles. But if it's lowered I'd do it more often.
Old Jan 13, 2005 | 02:13 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sj993 &raquo;</TD></TR><TR><TD CLASS="quote">I do mine every 3000 miles along with my oil change. I think normal rotation is 5000 or 7500 miles. But if it's lowered I'd do it more often.</TD></TR></TABLE>
Wow that's frequent.
civic_saints1
Suspension & Brakes
Jul 27, 2007 01:59 PM
4drteg916
Suspension & Brakes
Feb 22, 2007 12:07 PM
donger
Jan 30, 2006 01:10 PM
ZTYPE_S
Mar 21, 2004 06:14 PM
clutch33
Oct 29, 2003 04:54 PM
