GS-R to ITR Cams
Old Jan 4, 2005 | 07:21 PM
4dooritr's Avatar
Default GS-R to ITR Cams
When your swaping ITR Cams into a stock GS-R engine do you NEED to upgrade the valves/valve springs ?
Or will the ITR cams work fine with out busting anything into the engine
Its on a 95 USDM motor.
Thanks
Old Jan 4, 2005 | 07:23 PM
1whitedc2's Avatar
if you're only doing the intake cam then it should be fine, cuz the intake springs are also double like the ITR, but not the exhaust springs, there may not be a catastrophic failure, but overtime frequent valve float or high lift would wear out the valve seat in the head and at the same time cause premature valve spring wear and the compliance of the spring is compromised, they start to yield and become less compliant...thus more damage to the valve seat in the head
Old Jan 4, 2005 | 07:40 PM
rough_draft's Avatar
they will work fine if you keep stop redline.
Old Jan 4, 2005 | 08:04 PM
ChaseIntegra's Avatar
Default Re: (omghi2ubbq)
I'm using CTR intake cam in 94 JDM GSR. It does fine, no problems. The only time you gotta worry about it is if you have an old like first gen motor.
Old Jan 4, 2005 | 08:27 PM
miketegra's Avatar
Default Re: (ChaseIntegra)
What kind of power increase can be expected when doing the GSR to ITR cam swap? Assuming no other mods or what about maybe with I/H/E ?
Old Jan 4, 2005 | 08:59 PM
1whitedc2's Avatar
i suggest getting skunk2 IM, the ITR cam will improve your top end, but the GSR IM won't give it enough air, that's my opinion, you'll need couple more things to make it run smoother, like VAFC, full exhaust system, etc, but it'll be worth it, don't expect one single part to do it all,
Old Jan 4, 2005 | 09:04 PM
4dooritr's Avatar
Default Re: (1whitedc2)
the car has i/h/e, skunk2 manifold, 70mm TB w/ 70mm-66mm spacer, VAFC
Old Jan 4, 2005 | 09:11 PM
00s2KkId's Avatar
get it tuned with the VAFC after the cam install..... your stock valvesprings and retainers will work fine it you dont rev past stock redline
Formula
Mar 16, 2006 08:06 PM
darrinbrewer
Dec 19, 2002 08:23 AM
IgniteTeg
Jun 30, 2002 02:03 AM
bhcvc
Mar 19, 2002 09:17 PM
GSR -97
Nov 26, 2001 09:25 AM
