Hf hubs
Old Jan 4, 2005 | 06:55 PM
tcwcrxhf's Avatar
Default Hf hubs
Ok so just confirm what i already know or dont know
1. You need si hubs for b-series swaps
2. You can plug in hf axles in an si tranny (d16a6 swap)
3. How do you replace an upper ball joint?
Old Jan 4, 2005 | 07:16 PM
cbp_crx's Avatar
Default Re: Hf hubs (tcwcrxhf)
yes, you need si hubs for a b series swap, someone correct me if im wrong but, i think that hf axles will work in an si tranny, also i was told but dont know if its true or not, that if the upper ball joint is bad, your supposed to replace the whole upper control arm
Old Jan 4, 2005 | 07:30 PM
jlicrx's Avatar
Default Re: Hf hubs (crx_si6)
yes, you need either Si or DX hubs for B-series swap
yes, HF axles fit right into Si transmission
yes, you need to replace entire upper control arm
Old Jan 4, 2005 | 08:40 PM
91tegrals's Avatar
bam listen to that man he knows wat hes talkin about..
Old Jan 4, 2005 | 09:01 PM
kid-honda's Avatar
Default Re: Hf hubs (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote"> you need to replace entire upper control arm</TD></TR></TABLE>
Not true some 89's and al 90/91's the balljoints can press out.
Old Jan 5, 2005 | 04:16 AM
tcwcrxhf's Avatar
kewl thanks guys
spunautosports
10
Oct 28, 2006 10:08 AM
e jay one
May 26, 2006 01:34 PM
pinecone
May 16, 2006 05:45 AM
PBrex
Feb 6, 2004 05:13 PM
pdiddyparsons
Feb 18, 2003 11:34 AM
