size matters, right? 91 si sway bar links size?
On a 91 civic si, are the front sway bar links 19mm? Not sure and just needed someone to confirm or tell me the correct size. Thx
I think you're combining two part names together...
There is the sway bar (#1 in the pic below) and then there are the end links (#15 in the pic below) that attach it to the lower control arms.
The front swaybar on the 89-91 Civic-Si/88-91 CRX-Si is 18mm diameter. I've never checked the endlinks, no one really measures these, but they are definitely smaller (probably 5-6mm thick).
The Civic Wagon/RT-4WD used the 19mm diameter front sway bar.
