Will this work..
Old Jan 4, 2005 | 04:24 PM
CivicHB89's Avatar
Default Will this work..
Hey, i saw under these 2 websites...
http://www.geocities.com/teampimports/fuelinj.html
and
http://www.fourthgenhatch.com/
They both say i need a Pm6 Ecu for my MPFI intake swap from the DPFI. So i did a little searching. Went to ebay..Saw these..Was wondering if they would work for what i need to do.
http://cgi.ebay.com/ebaymotors...33597
and
http://cgi.ebay.com/ebaymotors...=6755
If they both will work..Lemme know which one you think i should go for.
Old Jan 4, 2005 | 04:27 PM
Mr_CRX's Avatar
Default Re: Will this work.. (CivicHB89)
That first eBay item is just a chip for the ECU, not the actual ECU.
You need the second one: a PM6 ECU.
Old Jan 4, 2005 | 04:32 PM
CivicHB89's Avatar
Default Re: Will this work.. (Mr_CRX)
Thanks for the help. Anyone else have input on this?
Old Jan 4, 2005 | 04:44 PM
mellon's Avatar
Get the second one, its the complete ECU.
Old Jan 4, 2005 | 04:50 PM
CivicHB89's Avatar
Default Re: Will this work.. (mellon)
Alright kool thanks. Ill be buying that in a little bit.
Old Jan 4, 2005 | 05:11 PM
crx90rcr's Avatar
im in middle of doing this swap and im stuck like crazzy old intake mani is stuck on brace and one of my pins broke off my wires at the ecu harness
Old Jan 4, 2005 | 07:14 PM
CivicHB89's Avatar
Default Re: Will this work.. (crx90rcr)
Yeah, i got half of the intake apart (easier to get to everything by takin it apart piece by piece i think) but i cant get to the brace, so im just gonna yank the whole engine, i wanna clean the engine bar, put nice new blue wire covers over everything, nice blue hoses to.
Old Jan 4, 2005 | 10:05 PM
doublethink's Avatar
you really do not need to pull the engine. but to each their own.
Old Jan 4, 2005 | 10:19 PM
Malgerus's Avatar
Default Re: Will this work.. (doublethink)
Just remove the engine bay wiring harness (there are clips on the driver's side and passenger side shock tower areas).
Then, use some trailer hitch wiring connectors with your new wires so that you can easily pull it out again if you have to. I can't begin to describe my appreciation for trailer wiring harnesses. They rule.
RACEPAK
Aug 2, 2006 09:16 AM
mr.beeks
Sep 25, 2003 10:59 PM
