EF9 Civic SiR knuckles....what car has bearings that match?
Old Jan 4, 2005 | 03:55 PM
virginia_dude's Avatar
Default EF9 Civic SiR knuckles....what car has bearings that match?
1991 EF9 Civic SiR knuckles....what car has bearings that match?
Swallowed my right bearing.....need a replacement....I know its NOT 90-91 Civil 4 door....this bearing is a LOT bigger. Any idea what car has same bearing?
Now I ned to convince Advance auto to take this thing back.
Old Jan 4, 2005 | 04:07 PM
EL Vap133's Avatar
Default Re: EF9 Civic SiR knuckles....what car has bearings that match? (virginia_dude)
I believe you need DA bearings.
Old Jan 4, 2005 | 04:16 PM
Tyson's Avatar
interesting. its even bigger than EX? what else is different about the knuckle? rotor, caliper?
Old Jan 4, 2005 | 04:20 PM
EL Vap133's Avatar
Default Re: EF9 Civic SiR knuckles....what car has bearings that match? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">interesting. its even bigger than EX? what else is different about the knuckle? rotor, caliper?</TD></TR></TABLE>
I believe the SiR knuckles like the DA knuckles are a tiny bit taller than regular ol EF/EX knuckles.
Old Jan 4, 2005 | 04:31 PM
Tyson's Avatar
Default Re: EF9 Civic SiR knuckles....what car has bearings that match? (EL Vap133)
im further curious. whats bigger about the bearing? i assume the outer diameter of the bearing is bigger, but is the inner diameter the same? (basically does it use the same Si hub? axle?) im asking either EF9 or DA knuckle.
(i honestly have ignored all integra brake swap threads, just did a search and didnt find my info)
Old Jan 4, 2005 | 04:53 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">im further curious. whats bigger about the bearing? i assume the outer diameter of the bearing is bigger, but is the inner diameter the same? (basically does it use the same Si hub? axle?) im asking either EF9 or DA knuckle.
(i honestly have ignored all integra brake swap threads, just did a search and didnt find my info) </TD></TR></TABLE>
Now that I don't know...
Old Jan 4, 2005 | 04:56 PM
wu tang's Avatar
(sorry to hijack) but i'm selling sir knuckles...
Old Jan 4, 2005 | 05:00 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
I believe the SiR knuckles like the DA knuckles are a tiny bit taller than regular ol EF/EX knuckles.</TD></TR></TABLE>
I think the SiR ones are the same as all the other EF's as far as geometry is concerned. I couldn't visually see any height difference when I matched them up against EX knuckles. However, I could see the difference between DA and EX knuckles.
The main physical differences of the SiR knuckle are that they are beefier design (heavier), made for B16 axles to fit with dust seal thing, have the tie rod hole location more inwards towards the center of the car, and have the DA/EX brake rotor size. You can use the EX caliper and rotor on them if needed.
Also, they do indeed use the same bearing as the DA - larger outer diameter than all the USDM ED knuckles. EX uses the same bearing as Si, DX, LX. If you tried to fit a USDM bearing in there it would be super loose.
Old Jan 4, 2005 | 05:04 PM
These came off a 1/2 cut 91 SiR I bought for my swap.....it takes EX brake pads..(matched them up at parts store)..I assume the Calipers are same as EX too.
Uses stock Tie rods....in my case DX.....the Bearing is almost 1/2" bigger than EX...
Old Jan 4, 2005 | 05:05 PM
4drEF's Avatar
Keyboard Humorist
Default Re: EF9 Civic SiR knuckles....what car has bearings that match? (wu tang)
You need to delete that "I have them for sale" reply and go post in the classifieds.
Old Jan 4, 2005 | 05:06 PM
Outer diameter is larger and inner diameter is larger....only thing the same is depth.
I have 90-93 teg axels on it now....tore a boot something last winter and ran on it a long time without knowing it was tore in 1/2.
Old Jan 4, 2005 | 05:07 PM
Default Re: EF9 Civic SiR knuckles....what car has bearings that match? (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
Also, they do indeed use the same bearing as the DA - larger outer diameter than all the USDM ED knuckles. EX uses the same bearing as Si, DX, LX. If you tried to fit a USDM bearing in there it would be super loose.</TD></TR></TABLE>
the hub wouldn't even be close to fiting either.....SiR is way beeffier (bigger) than the EX.....
Old Jan 4, 2005 | 05:08 PM
Tyson's Avatar
thanks. this is interesting. i guess they did beef it up for the b16 engine.
Old Jan 4, 2005 | 05:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wu tang &raquo;</TD></TR><TR><TD CLASS="quote">(sorry to hijack) but i'm selling sir knuckles...</TD></TR></TABLE>
Would be tempting but I can get a bearing for about $60 in 24 hours......this is my backup car....not my daily driver.....thinking about selling it soon however.
Old Jan 8, 2005 | 12:52 PM
wu tang's Avatar
cool
Old Jan 11, 2005 | 04:28 PM
ShiroX's Avatar
the DA bearing is definately larger than the crx/civic hub bearing
so does anyone know what bearing this guy needs? Im just curious also.
btw for reference
92+ civic/integra bearings are the same dependings on ABS or NonABS
Non ABS uses a small bearing almost identical to the pre 92 crx/civic bearing
however all ABS models use a larger bearing
so my choices for you would be try the bearing
BCA/National#513241= DA Hub Bearing or
BCA/NAtional #510030 = 92+ Civic /Integra w/ ABS
Old Jan 12, 2005 | 07:11 AM
Default Re: EF9 Civic SiR knuckles....what car has bearings that match? (VTeC4TheChildren)
My EF-9 knuckles (1991 Civic SiR) used 90-93 Integra bearings.............Car is on the road now.....those are exact fit replacements.
Old Jan 12, 2005 | 07:49 AM
4drEF's Avatar
Keyboard Humorist
"Also, they do indeed use the same bearing as the DA - larger outer diameter than all the USDM ED knuckles. EX uses the same bearing as Si, DX, LX. If you tried to fit a USDM bearing in there it would be super loose."
Told you so! lol
Old Jan 12, 2005 | 12:16 PM
The EF-9 hub would not fit in any HONDA bearing unless driven in with a Nuke....thre is almost a 1/2 difference in the inner and outer dimensions between the DA hub bearing adn all the Honda civic bearings.
Old Jan 12, 2005 | 12:20 PM
4drEF's Avatar
Keyboard Humorist
yup.
basically what I said, no?
just posting again to ... I dunno... ummm... guess I'm bored!
Old Jan 12, 2005 | 12:26 PM
Basicly.................
Old Jan 12, 2005 | 12:27 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">"Also, they do indeed use the same bearing as the DA - larger outer diameter than all the USDM ED knuckles. EX uses the same bearing as Si, DX, LX. If you tried to fit a USDM bearing in there it would be super loose."
Told you so! lol</TD></TR></TABLE>
No, I called it first.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I believe you need DA bearings. </TD></TR></TABLE>
Old Jan 12, 2005 | 02:21 PM
ShiroX's Avatar
when you installed the SIR knuckles did you have to cut off the inner tie rod end 1"?
http://home.socal.rr.com/civic...x.htm
as stated on this page?
and why was this modification necessary ?
Old Jan 13, 2005 | 12:15 PM
No....becasue my car is a DX....it uses Identical Tie rod ends....the long ones....I think the Si Rack was longer and used shorter tie rod ends.
Old Jan 13, 2005 | 01:21 PM
4drEF's Avatar
Keyboard Humorist
The SiR knuckles have the tie rod mounting locations in a different location than the stock Si,Dx,Ex... knuckles do. The locations are placed closer to the rack. If you have a set fo "SiR" knuckles and the tie rod mounting location is in the same place as your stoc knuckles - well, then you don't have SiR knuckles. you probably got DA ones.
The car in the mod you linked to is my 91 LX with power steering.
When I first put the knuckles on and set the tie rods in place there was a horrible obvious toe-out problem that you could see with your eyes - no need to diagnose it with an alignment!
With the tie rods adjusted all the way in there was still a little toe out.
With the tie rod lock nut removed and then adjusting the toe all the way in I could have been fine, BUT I wanted to have the lock nut on there.
So I ended up doing the mod.
Now I'm able to use the lock nuts and there is enough threads on the tie rods for good adjustment when getting an alignment.
