Building RSX S on boost what should I do??
Old Jan 4, 2005 | 02:39 PM
slrh22hatch's Avatar
Default Building RSX S on boost what should I do??
I recently purchased a 04 RSX S and want to go boost. I want to make a lot of power. Im having Benson sleeve my block and staying at 86mm bore. Im using 9:1 CP piston and Crower billet rods. Im going to use the Rev Hard kit unless you can recommend a better kit. Im new to the industry so your help would be greatly appreciated. What do I do as far as the fuel system fuel pump, regulator etc. Suspension? What do i do ??? All suggestions would be appreciated. Thanks
Old Jan 4, 2005 | 05:18 PM
Luke J's Avatar
Default Re: Building RSX S on boost what should I do?? (slrh22hatch)
You might get a better response in the forced induction forum, or DC5/EP3 forum..
Old Jan 4, 2005 | 05:19 PM
.dave's Avatar
i HAS questions ?
You'd probably get a lot more help in the Forced Induction forum. Research the Hondata K-pro and whats needed to run it on a boosted RSX for fuel management. Everything else seems good to go. Good luck.
Old Jan 4, 2005 | 05:47 PM
Luke J's Avatar
Default Re: Building RSX S on boost what should I do?? (one.6)
also check http://www.k20a.org
Old Jan 4, 2005 | 07:27 PM
Danger's Avatar
Default Re: Building RSX S on boost what should I do?? (Lucky925l)
joey , when the hell did you buy that car ?
slrh22hatch
Jan 20, 2005 07:26 PM
slrh22hatch
Jan 5, 2005 02:42 PM
M3SMG
Jul 17, 2003 08:00 AM
Westrock2000
13
Mar 24, 2002 04:07 AM
2k2civic
Jan 29, 2002 05:10 PM
