**Cleaned up Shop Takeing Offters on ALL**
95 Honda civic
Gray console with arm rest
Gray glove box
Gray steering wheel
Gray bottom center console with ash tray
Both air bags in gray driver and passenger
Under driver side panel gray with fuse cover
OEM Passenger side turn single light
Passenger side power mirror in black
Driver side manual mirror in black
OEM rear wing shipped
95 Civic Ex fuel injectors
95 Civic LX dizzy with rotor and cap
95 Civic EX dizzy good for parts or core
95 Civic EX fuse box in Engine bay
95 Civic Ex rad fan
95 civic EX A/C condenser
95 Civic power steering pump
95 Civic EX APC 9.3mm spark plug wires
95 Civic Shift linkage
95 Civic EX Flywheel
95 Civic EX T/B with MAP & TPS sensors
95 Civic Rear L bracket
95 Civic EX Front & Rear Seats Gray Pick up Only
95 Civic Lx cluster with tach
97 civic
97 Civic EX Vtec Sol
99 Ls
95 rear tail lights
99 Ls crank sensor
94 Ls passenger power mirror white
99 Ls head bolts
99 Ls main bolts 25
99 Ls knock sensor
99 Ls flywheel
00 Gsr
2000 Gsr Cams & stock Cam gears with 37k <----SOLD
96 Gsr Cluster with 0 miles
B16
Obd 1 fuel rail
Obd 1 fuel injectors
B16 head bolts
B16 dual intake valve springs & exhaust springs with retainers
B16 power steering power bracket
Modified by DIFFUT'S INC. at 6:13 PM 1/23/2005
