(searched) S2000 cluster into dc2
Old Jan 4, 2005 | 01:37 PM
silent-chris's Avatar
Default (searched) S2000 cluster into dc2
I was searching and found nothing on how swap it into a dc2. All I was ef eg and ek all that i am wondering is if anyone has been able tp getthe speedo to work in the dc2. Has anyone ever gotten the speedo to work when swapped from the s2k? Any input will be appreciated.
Old Jan 4, 2005 | 01:47 PM
MikeTV
Guest
Posts: n/a
Default Re: (searched) S2000 cluster into dc2 (silent-chris)
yes I'd like to know to, I am looking to do this also within the next month.........
Old Jan 5, 2005 | 03:24 PM
Default Re: (searched) S2000 cluster into dc2 (Eclipse spanker)
anyone?
Old Jan 5, 2005 | 11:16 PM
calxtreme's Avatar
bump'
Old Jan 6, 2005 | 03:30 AM
dFreezy's Avatar
Default Re: (calxtreme)
search again, this question has been asked several times...no one has successfully pulled it off (or at least done and wrote about it), most have problems with the speedo not working.
if you search 's2k dc2 cluster' or 's2k integra cluster' the other threads show up
Old Jan 6, 2005 | 08:39 AM
Default Re: (dFreezy)
i only got 2 results under s2k integra and none from the other one what i am really looking for is getting the speedo to work i can figure the other stuff for the swap i have an itr cluster in my crx.
Old Jan 8, 2005 | 06:51 PM
djmatix's Avatar
it has been tried and tried. They have everything working but the speedo because the speed sensor on the s2000 tranny is a digital signal. It works off pulses that the cluster translates into speed. A good friend of mine is doing it right now into an eg, and thinks he may have figured out how to do it. Something about a blitz digital speed reader. The speed sensor is also digital and is trying to figure out how to pipe the signal into the cluster. I believe he is pretty close to knowing if its going to work or not. Everything else is functioning. Even when the key is in the ignition, the little key icon comes on, as well as the trunk...well you get the point.
Old Feb 4, 2005 | 10:15 AM
AFTERZERO's Avatar
Default Re: (djmatix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djmatix &raquo;</TD></TR><TR><TD CLASS="quote">it has been tried and tried. They have everything working but the speedo because the speed sensor on the s2000 tranny is a digital signal. It works off pulses that the cluster translates into speed. A good friend of mine is doing it right now into an eg, and thinks he may have figured out how to do it. Something about a blitz digital speed reader. The speed sensor is also digital and is trying to figure out how to pipe the signal into the cluster. I believe he is pretty close to knowing if its going to work or not. Everything else is functioning. Even when the key is in the ignition, the little key icon comes on, as well as the trunk...well you get the point.</TD></TR></TABLE>
Whats is the update??^^
Type R Teg
Jan 26, 2010 07:13 AM
slogsr
Feb 28, 2009 03:54 PM
rolin rotas
Oct 12, 2008 05:42 PM
HondaGuRu
Jul 1, 2003 05:18 AM
Cosworth
Sep 4, 2001 02:58 PM
