Suspension & Brakes Theory, alignment, spring rates....
Stock R susp. vs Tein Flex. a question about swapping the 2.
Old Jan 4, 2005 | 01:31 PM
baonest's Avatar
Default Stock R susp. vs Tein Flex. a question about swapping the 2.
ok so i have an R now. with stock susp. its awesome.
i also have an LS that i was prepping for the track, it has Tein susp (that would also fit the R).
just curious on what you guys would do, would you swap the Tein onto the R.
or just keep the R stock, and try to sell the Tein susp.
Old Jan 4, 2005 | 01:33 PM
Tyson's Avatar
Default Re: Stock R susp. vs Tein Flex. a question about swapping the 2. (baonest)
if you think the type R suspension is as you say "awesome", then dont mess with it.
what are you doing with the LS if you sell the tein?
Old Jan 4, 2005 | 01:47 PM
baonest's Avatar
Default Re: Stock R susp. vs Tein Flex. a question about swapping the 2. (Tyson)
well the LS has full cage, gutted. i was working on it for a track car til the motor went on it. right now its just sitting in my driveway. if i can get a decent deal with the Teins still on the LS then i might leave them on and try to get rid of the shell.
the R susp will be put to test mid feb. at VIR. so then ill see if its necessary for an upgrade
Old Jan 4, 2005 | 07:04 PM
Mike_C's Avatar
i'd pick up a b18b, throw it in the ls, and have a damn fine track car. it's an h4 beast, and can also run in scca.
yes, the r suspension is great, but the shocks are a bit soft for the track. if you're deadset on getting rid of the ls, i'd sell the teins, pick up some koni yellows, get them valved a little stiffer, and run the stock r springs. i've been in rj's car with that exact setup and it felt pretty damn good while still being very streetable.
Old Jan 4, 2005 | 10:19 PM
baonest's Avatar
Default Re: (Mike C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C &raquo;</TD></TR><TR><TD CLASS="quote">i'd pick up a b18b, throw it in the ls, and have a damn fine track car. it's an h4 beast, and can also run in scca.
yes, the r suspension is great, but the shocks are a bit soft for the track. if you're deadset on getting rid of the ls, i'd sell the teins, pick up some koni yellows, get them valved a little stiffer, and run the stock r springs. i've been in rj's car with that exact setup and it felt pretty damn good while still being very streetable.</TD></TR></TABLE>
thanks for the input
menmydc5
18
Sep 2, 2007 09:19 AM
94typeR
Apr 12, 2007 05:07 PM
REVHIGH
190
Nov 7, 2004 08:52 PM
Civic Si Kid
18
Jul 26, 2004 08:20 PM
B18B1DOHC
Nov 30, 2003 08:54 PM
