B16 Knock Sersor LocatioN
Old Jan 4, 2005 | 12:38 PM
DC2tuner's Avatar
I Think I'm TOO White For This Thread
Default B16 Knock Sersor LocatioN
I have a B16A and i cant figure out if this is the knock sensor location or not. would a ls knock sensor fit? thanks alot
Old Jan 4, 2005 | 12:50 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: B16 Knock Sersor LocatioN (gsrpwr2004)
top is knock sensor*
mid w/ ? is coolent temp swick for rad. fans**
low is oil presure swich goes to oil light**
*i have never seen a knock sensor block but i' remember that it's just below te head on back of block
** i know these are true for a D block and guess there the same for a B
Old Jan 4, 2005 | 01:21 PM
APEX CRX's Avatar
that is where a knock sensor would be. But that block looks like a 1st gen right? the hole needs to be threaded for the knock sensor.
Old Jan 4, 2005 | 01:53 PM
crxkane's Avatar
Default Re: B16 Knock Sersor LocatioN (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">that is where a knock sensor would be. But that block looks like a 1st gen right? the hole needs to be threaded for the knock sensor.</TD></TR></TABLE>
It should already be threaded, I know mine was. and the ls does not come with a knock sensor.
Old Jan 4, 2005 | 02:04 PM
:__H__:'s Avatar
the LS doesnt have a knock sensor. only vtec motors.
EDIT: i guess someone told you before i finished typing...
Old Jan 4, 2005 | 02:14 PM
type Gendy's Avatar
Default Re: B16 Knock Sersor LocatioN (:__H__:)
You sure thats a b16? Doesnt look right/
Old Jan 4, 2005 | 02:18 PM
90crxsib16's Avatar
Default Re: B16 Knock Sersor LocatioN (Evil Sick hatcheM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Sick hatcheM &raquo;</TD></TR><TR><TD CLASS="quote">You sure thats a b16? Doesnt look right/</TD></TR></TABLE>
Old Jan 4, 2005 | 03:40 PM
mikerbike's Avatar
Default Re: B16 Knock Sersor LocatioN (90crxsib16)
It looks like a B engine to me. I see an oil cooler. Those came on the B16A engines, so I am guessing it looks a lot like a B16A.
Old Jan 5, 2005 | 03:50 PM
jdeemseerx's Avatar
Default Re: B16 Knock Sersor LocatioN (mikerbike)
its the bottommost arrow you have on the pic its right next to your oil filter that wire gets hooked up to your computer for the vtec it wont work without it
Old Jan 5, 2005 | 03:58 PM
drdisco69's Avatar
Default Re: B16 Knock Sersor LocatioN (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">its the bottommost arrow you have on the pic its right next to your oil filter</TD></TR></TABLE>
NO. That is the oil pressure switch, seeing as how it's next to the oil filter, in the oil feed galley...
I think the B17 came with an oil cooler, and some B18Cs also.
gabrielsousa
Nov 4, 2015 04:12 PM
KURUPTinc
Jun 22, 2005 11:03 PM
abbas
May 2, 2005 02:23 PM
DC2tuner
Jan 4, 2005 12:43 PM
B.
Sep 3, 2003 04:32 PM
