What's the best way i sholud do, Using the type-r manifold or my stock B16 manifold?
Old Jan 4, 2005 | 09:13 AM
92_EGhatch's Avatar
Default What's the best way i sholud do, Using the type-r manifold or my stock B16 manifold?
I Heard most peple said that Type-R manifold doesn't really make a difference on the B16A3 delsol motor. Because it's about the same ratio & nothing different.
SO my ?? is that should i use the type_r manifold or rather keep it stock.
Old Jan 8, 2005 | 07:04 AM
ek2k's Avatar
Default Re: What's the best way i sholud do, Using the type-r manifold or my stock B16 manifold? (92_EGhatch
it will not make a difference you can feel like 10 horsies but the itr manifold is much better and i think it comes mildly ported from the dealer because after all it is for a race car but it you port the manifold you WILL feel it better,
Old Jan 8, 2005 | 01:48 PM
92_EGhatch's Avatar
Well i have just put the itr mainfold in my B16, and just now started the ignition or started the engine. and have a problem. My engine sounds like it's leak, and rpm is at 2000 when i start the engine.
*What i used is the stock intake manifold gasket, the b16 throttle, and the B16 fuel line.
*WHat happen? it leaks from the throttle body, and RPM is @ 2000.
Organization
20
Jul 25, 2011 05:27 PM
''Simon''
12
Feb 11, 2008 04:51 AM
92_EGhatch
Jan 8, 2005 06:59 PM
paulzy
Aug 8, 2001 01:08 PM
