dash question
Old Jan 4, 2005 | 07:31 AM
superbeastcrx's Avatar
Default dash question
will a dash out of a 90-91 crx work in a 89 crx hf?
Thanks in advance for the time and help.
J.D.
Old Jan 4, 2005 | 07:32 AM
crxgator's Avatar
Default Re: dash question (superbeastcrx)
yes...
Old Jan 4, 2005 | 07:35 AM
Default Re: dash question ([crx]Hated it!!!)
is all the wireing the same?
Old Jan 4, 2005 | 07:40 AM
crxgator's Avatar
no...
Old Jan 4, 2005 | 07:41 AM
what's different?
Old Jan 4, 2005 | 07:42 AM
crxgator's Avatar
a whole bunch, cluster plugs/wiring, dash wiring for hazards, defroster and dimmer are different plug shapes, sunroof wiring on the si...
Old Jan 4, 2005 | 07:46 AM
i already figured out what to do for dash wiring for hazards, defroster and dimmer are different plug shapes. but how do i do the wireing for the gauges/ what is different?
Old Jan 4, 2005 | 07:47 AM
crxgator's Avatar
why are you changing the wiring first off?
do you also want the dash because its black/grey?
Old Jan 4, 2005 | 07:51 AM
i moved the dimmer,hazard,defroster to the spot right under the steering wheel(the removeable plastic plates for after market togal switches, ETC) yes i like black and gray more than blue. the wireing is all i have left.
Old Jan 4, 2005 | 08:11 AM
crxgator's Avatar
well what i would have done was, swap in the dash and then purchase the cluster cover and switch with the wiring ends and splice the new plugs in...i would have left the stock hf cluster as well...changing the whole wiring harness is going to be a pain...
Old Jan 4, 2005 | 08:41 AM
so i need to buy a stock hf dash harness and switch the ends? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [crx &raquo;</TD></TR><TR><TD CLASS="quote">Hated it!!!]well what i would have done was, swap in the dash and then purchase the cluster cover and switch with the wiring ends and splice the new plugs in...i would have left the stock hf cluster as well...changing the whole wiring harness is going to be a pain...</TD></TR></TABLE>
please explain this as if i was stupid i know motors not electronics!
Old Jan 4, 2005 | 08:43 AM
crxgator's Avatar
where is the stock hf harness now?
Old Jan 4, 2005 | 08:45 AM
in the hf i sold.
Old Jan 4, 2005 | 08:46 AM
but i can get one preaty easily!
plsarestupid
Jun 30, 2011 05:33 AM
gummiegorilla
Jul 30, 2009 07:32 PM
4DRmafia
10
Jan 7, 2007 07:21 PM
