Need help to install the sender for the electric fuel pressure
Old Jan 8, 2002 | 08:01 AM
MUGENTYPER's Avatar
Default Need help to install the sender for the electric fuel pressure
wassup people! i have a electric fuel pressure gauge everthing is already wired and installed except the SENDER.. where do i tap/mount the sender?? i have a 94 civic coupe with B18C5 swap. please help!! [
Old Jan 8, 2002 | 01:37 PM
ck279's Avatar
Default Re: Need help to install the sender for the electric fuel pressure (MUGENTYPER)
What brand guage is it? I do not know of any guages that do not come with instructions on how to mount the sender.
You can also find some images of mounted fuel pressure guages by doing a search on here and the Forced Induction board. That should help you out.
Old Jan 8, 2002 | 06:21 PM
MUGENTYPER's Avatar
Default Re: Need help to install the sender for the electric fuel pressure (ck279)
THANKS FOR THE ADVICE... ILL LOOK INTO IT.
Old Jan 8, 2002 | 06:57 PM
KekeK_5G's Avatar
I know myself and others have used the B&M gauge to our advantage. All that has to be done is run a tee off the special B&M banjo bolt, mount the gauge in one end and the sender for the in car gauge on the other end. All the fittings are 1/8 NPT thread, the tee would be male to the banjo bolt and the other 2 holes female. HTH.
420aNT
Mar 20, 2003 05:29 AM
turbohf
Feb 2, 2003 10:18 PM
twincamrex
Aug 27, 2002 12:55 PM
MUGENTYPER
Jan 9, 2002 07:56 AM
mike2016
Jul 3, 2001 01:01 PM
