will they still accept recalls for the eg civic?
haha, i was just reading/researching cuz my automatic daily driver civic is messed up.
NHTSA Recall History
1992-94: Retaining clip at automatic transmission can come off, so position of lever does not match actual transmission gear range. 1994: Passenger-side airbag module on small number of cars may contain incorrect inflator, therefore unable to provide adequate protection.
^^^ what happens when the retaining clip comes off?
Automatic transmission: Cars with high mileage may begin to shift more harshly, which may be corrected by adding a bottle of Lubeguard conditioner to the automatic-transmission fluid. (1992-95)
^^^ does this work? where can i get this?
Trunk latch: There may not be sufficient clearance on the trunk latch making it hard to open with the key. (1992-95)
^^^ hella true
what my car does: when i turn and start accellerate... around 2500, my car's transmission "slips" as in "i dont accellerate and i just rev". i just rev until let's say 5500 and then i start accellerating... only it accellerates like im in first gear
other times the transmission will just go kaput and just rev and i have to coast to the side while i curse the car.
but the strangest thing is.. is that when i turn off the car, and turn it on again it's ok for the next 6 miles
any thoughts?
oh and i did a full flush using honda ATF like 3 weeks ago. so that rules out the atf being bad
Modified by carbing'ed at 2:06 AM 1/4/2005
^^^ hella true
any thoughts?oh and i did a full flush using honda ATF like 3 weeks ago. so that rules out the atf being bad
Whe I took my 94 hatch to get a new master cylinder I asked them to do a recall check. They said everything was taking care of. Just go to the dealer and they will run your VIN and tell you if the work has already been performed. It won't cost you a thing. at least it diidn't at my dealer.
If the recall work has not already been done, they are required to do it if you ask. Doesn't matter how old the car is.
Take your VIN and have them run it through the computer for you to check on recall status.
BTW, sounds like you're going to be needing a new transmission in the near future . . . better start saving up.
what kind of recalls did they have on 98 Civic eg's? i think i'll go check this out when i get outta school today.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CivicChik »</TD></TR><TR><TD CLASS="quote">what kind of recalls did they have on 98 Civic eg's? i think i'll go check this out when i get outta school today.</TD></TR></TABLE>
http://www.alldata.com/TSB/24/982436A4.html
3 recalls.
3 recalls.
thanks.
i had just found that site when you replied lol. i'm goin to scott honda of west chester after school and checkin this out. why would they recall floor mats? seems kinda weird. sure theres a good reason.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">98 civic is the EK or EM...
There are no USDM '98 EKs or EMs.
She has an EJ8.
</TD></TR></TABLE>There are no USDM '98 EKs or EMs.
She has an EJ8.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 »</TD></TR><TR><TD CLASS="quote">If there is something that was recalled what do you have to do to get it fixed.</TD></TR></TABLE>
Make an appointment to have the recall work done at your local Honda dealership.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Make an appointment to have the recall work done at your local Honda dealership.</TD></TR></TABLE>
Cool... I looked on that site and my ignition switch was recalled
Wow. Theres so much crap for my car.
Can someone check it out and tell me what I CAN do?
http://www.alldata.com/TSB/24/972438AO.html
Can someone check it out and tell me what I CAN do?http://www.alldata.com/TSB/24/972438AO.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic4less »</TD></TR><TR><TD CLASS="quote">Wow. Theres so much crap for my car.
http://www.alldata.com/TSB/24/972438AO.html</TD></TR></TABLE>
you can ge the recalls done for free.
the rest you pay for.
Can someone check it out and tell me what I CAN do?http://www.alldata.com/TSB/24/972438AO.html</TD></TR></TABLE>
and to teh first guy
that first recall syas exactly what happens...the shifter wont always point to teh gear you are in cause hte cable slips.
to me it sounds like you ar jsut gonna have to buckle down and get another tranny soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">
the rest you pay for.</TD></TR></TABLE>
Thanks a lot
. Ima call the local honda dealer soon.
Thanks a lot
I only see 2 recalls. The rest are just technical service bulletins that may or may not apply to your particular vehicle.
Also, keep in mind that any recalls dated before the date your car was delivered to its original owner will have already been taken care of. This does not necessarily include any technical service bulletins.
far as i know they still do the fixes...... i had my 92 civic si checked for them and it will say in the computer at the dealership through vin#'s if any recall action has not been done...
