would it be safe to use skunk2 stage 1 cams and skunk2 retainers with omnipower valve springs?
Old Jan 3, 2005 | 08:40 PM
undagroundrican's Avatar
Default would it be safe to use skunk2 stage 1 cams and skunk2 retainers with omnipower valve springs?
this is my set up the reason why i dont get the skunk2 valve springs is because its too much money and i can get the omnipower springs cheap would it be safe to have this set up in a gsr motor any feedback will do thanks!
Old Jan 3, 2005 | 08:43 PM
Dan GSR's Avatar
Default Re: would it be safe to use skunk2 stage 1 cams and skunk2 retainers with omnipower valve springs? (
why not get the springs and retainers thru omni? they are made to fit each other
Old Jan 3, 2005 | 11:33 PM
sPaRk'iT's Avatar
As long as all the measurements and fitting are right, it should be fine, I wouldnt see a problem. But somebody correct me if im wrong.
Old Jan 5, 2005 | 09:01 PM
00Red_SiR's Avatar
All Motor Mentor
The stage 1's will work with your stock valvetrain ok. I just upgraded my exhaust springs with ITR's when I installed my cams and had no troubles at all.
b16bekhatch
Mar 30, 2009 02:37 PM
Boosted R
Feb 12, 2006 08:19 AM
jdmcoop
10
Aug 10, 2005 05:13 PM
PSU-TEG
Aug 13, 2002 10:36 AM
