shipping a type r tranny via UPS
Old Jan 3, 2005 | 05:25 PM
nissanjon's Avatar
Default shipping a type r tranny via UPS
Hi,
I just received a brand new ITR transmission and I literally witnessed the UPS driver drop the package from the dolly onto the ground.
Now - I realize UPS doesn't handle each package like fine china, and I realize an ITR tranny should be pretty tough.
But - should I be concerned about internal damage? The exterior seems ok...
Thanks!
nissanjon
Old Jan 3, 2005 | 05:28 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Re: shipping a type r tranny via UPS (nissanjon)
Make sure you follow it up with UPS. It should be okay, but I have a friend with a 3000GT VR4 and UPS broke his clutch he ordered and didn't pay for it. It couldn't have fallen that far, or did it? Anyway, it should be cool.
Old Jan 3, 2005 | 05:36 PM
nightrider's Avatar
was there insurance on the delivery?
Old Jan 3, 2005 | 05:50 PM
GZR4DR's Avatar
Default Re: shipping a type r tranny via UPS (nightrider)
If the box was rated at 100+ lbs. and it was properly packaged you should have nothing to worry about.
If it was poorly packed and it was dropped 6+ inches yes damage could occur. You should however see cracks on the outside of the casing before any damage is caused to the internals. The trans. casing is not that thick.
Old Jan 3, 2005 | 05:53 PM
99 TYPE R's Avatar
Yea follow up say its fucked up, when i got my R block from acura fed ex drop it repacked it in a 35lb box not even back on the origanal crate or 1 like it and left it at my house. I open it and the oil pan is bent and the casting for trans bolt was bent , so i bitched them out also with acura and ended up getten another bran new R block and fed ex let me keep the old 1 as welll. So i made out hopefully u will
Old Jan 3, 2005 | 09:11 PM
HmgLauj69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nissanjon &raquo;</TD></TR><TR><TD CLASS="quote">Hi,
Thanks!
nissanjon</TD></TR></TABLE>
i use to work at UPS, heavy boxes gets tossed around like nothing....mostly that tranny has been droped more than once, sorry bro
Old Jan 3, 2005 | 09:37 PM
Rice Is Best's Avatar
Default Re: shipping a type r tranny via UPS (HmgLauj69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HmgLauj69 &raquo;</TD></TR><TR><TD CLASS="quote">
i use to work at UPS, heavy boxes gets tossed around like nothing....mostly that tranny has been droped more than once, sorry bro</TD></TR></TABLE>
thats nice to hear
Old Jan 3, 2005 | 09:55 PM
Phish4199's Avatar
Default Re: shipping a type r tranny via UPS (KockAsian)
i just got done working for ups, not pretty i'd take a close look at it
Old Jan 3, 2005 | 11:07 PM
blackdelslo's Avatar
Default Re: shipping a type r tranny via UPS (Phish4199)
i wouldnt trust any of those shipping companys, always pack things as if no one gives a **** about it. (they dont )
Old Jan 4, 2005 | 12:12 AM
92TypeR's Avatar
FSAE
Default Re: shipping a type r tranny via UPS (delLudeVTEC)
I've shipped trannies using FedEx and they have always arrived in perfect condition.
The best way, which is the method I use, is to build a wood crate and fill it with an expanding styro-foam with the tranny already inside, it creates a huge shell and allows for no movement. Once the tranny arrives, you just gotta crack/chisel the shell with a knife.
Old Jan 4, 2005 | 12:35 AM
130R's Avatar
Default Re: shipping a type r tranny via UPS (92TypeR)
dont forget putting [FRAGILE] in the box helps too
Old Jan 4, 2005 | 01:28 AM
uNF$@#!'s Avatar
Default Re: shipping a type r tranny via UPS (carbing'ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbing’ed &raquo;</TD></TR><TR><TD CLASS="quote">dont forget putting [FRAGILE] in the box helps too</TD></TR></TABLE>
you think the guys at UPS getting paid minimum wage actually care?
sad but true.
i know two ups guys over in michigan who break everything that looks semi expensive by throwing it around on their lunch break
Old Jan 4, 2005 | 08:20 AM
Dave_B's Avatar
I've experienced many things that have been improperly handled by both UPS and FedEx. I would carefully examine the trans and definitely call about the guy who dropped it especially if you witnessed it. Good luck with it
Old Jan 5, 2005 | 06:37 PM
StorminMatt's Avatar
Default Re: (01PY0559)
The moral of the story: try to buy local (or at least within a reasonable drive) and pick up. Also remember that if the item has to be truck line shipped, it can actually be cheaper to drive a few hundred miles to pick it up. Even if you have to stay overnight in a motel. Also, when you actually pick up, you can check things out to make sure that everything is good before you pay. This is ESPECIALLY true if you are buying used goods. When you order online, you really don't know what you will get until you actually DO get it. And so much of the time, people end up disappointed.
nipcup101
Feb 28, 2008 09:30 AM
project-boosteD
Nov 8, 2004 06:05 PM
Chubz
Oct 13, 2004 01:22 PM
TurboBumblBee
12
Jan 18, 2003 07:19 AM
SleepinGSR
Mar 21, 2002 07:44 PM
