200 GSR LONGBLOCK 83MM Sleeved Arias Eagle Crower
I have been putting this together for a while and have other priorities that have to come first. I do not need to rush in selling this so dont try to lowball. I will seperathe the block from the head for the right price:...
Bottom End
2000 GSR Block with carfax
RS Machine Sleeves Bored to 83mm
Arias Pistons 9.5
Eagle rods
freshly cut crank with new bearings
New OEM Oil and Water Pumps
ARP Main Bearings
I have $2000 total in this bottom end
Top End
95 GSR Head
Slight port job
All Crower internals .5mm oversize valves,springs,retainers,new valve seals
OEM GSR cams and cam gears
Brand NEW EDELBROCK manifold
ARP Head studs
I have $1300 in this head
Everything is all setup and ready to go all you need ts a rear main seal and a timing belt. .......I also have some other things like a GSR transmission with low miles, shift linkage, axles, all motor mounts, Fidanza lightened flywheel (used), distributor, and wiring harness. Shoot some offers at me. I will let everything I have go for $4000 E-mail for pics
Bottom End
Arias Pistons 9.5
Eagle rods
ARP Main Bearings
Top End
95 GSR Head
Slight port job
ARP Head studs
boostedb18c
Jan 5, 2005 08:28 PM
