camber problem
Old Jan 3, 2005 | 03:33 PM
smikeL's Avatar
Default camber problem
wdup guys. i got a big *** camber problem. i was looking for a camber kit on ebay and came across this -> http://cgi.ebay.com/ebaymotors...33581
is that a legit kit ? or would you guys recommend something else.
Old Jan 3, 2005 | 03:36 PM
MolecularIntegra's Avatar
Default Re: camber problem (mikeL619)
I've never heard of it. It looks kind of weird but who knows. Ingalls are the tried and true standard of camber kits.
Old Jan 3, 2005 | 03:38 PM
IVI's Avatar
IVI
what is your big *** camber problem?
are the numbers equal on both sides?
Old Jan 3, 2005 | 03:42 PM
JustROLLIN's Avatar
Are you positive you are having a camber issue? Toe issues are often misinterpreted for camber issues... Is the abnormal wear on the outer or inner edge; or does the tire have swipes in a diagonal pattern across the entire face?
Old Jan 3, 2005 | 04:08 PM
Moogen Powah's Avatar
Default Re: camber problem (JustROLLIN)
Have you had an alignment recently? Is your car lowered? Because as stated above, it's the toe that is usually the culprit to uneven tire wear. I am currently dropped 1.8 inches around, have - 1.5 - 2.0 degrees of camber, had only an alignment, and all of my tires are wearing evenly.
Old Jan 3, 2005 | 04:25 PM
smikeL's Avatar
the wear is in the inside edge
Old Jan 3, 2005 | 04:27 PM
smikeL's Avatar
Default Re: camber problem (Moogen Powah)
yeah im also dropped about 1.8. i took my car to the alignment shop bout a month ago and they said camber seems to be the worse. my toe was off by a lil. they said fix my camber wit a kit jus enough so they can align it.
Old Jan 3, 2005 | 07:01 PM
Racermech's Avatar
Save up and get the Skunk2, or Omni power A arms. If you dont have the money for thoses save up and get the ingales kit at least.
Old Jan 3, 2005 | 07:17 PM
burnout289's Avatar
Default Re: camber problem (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeL619 &raquo;</TD></TR><TR><TD CLASS="quote">yeah im also dropped about 1.8. i took my car to the alignment shop bout a month ago and they said camber seems to be the worse. my toe was off by a lil. they said fix my camber wit a kit jus enough so they can align it.</TD></TR></TABLE>
bah. they will tell you that, but it's crap. do you have the sheet with the #s on it? toe eats up tires WAAY faster than camber unless you are really slammed. just get the toe set right and rotate often. my camber is -2.something degrees. front tires got all worn out cuz the toe was way off from dropping it.
Old Jan 4, 2005 | 08:50 AM
IVI's Avatar
IVI
Default Re: camber problem (burnout289)
my alignment is -1.9 both sides, dropped on neuspeed race.
i got excellant life out of my tires.
over 30,000 miles and they still had plenty of tread, however, i replaced them anyway.
Old Jan 4, 2005 | 09:19 AM
slowkaos's Avatar
Default Re: camber problem (IVI)
I had that camber kit on my last gsr and it fixed my problem. The only thing is, is that you are going to have to get your wheels realigned. When I put them on my car it pushed those wheels so far outa alignment. But yeah they do work and are easy to install.
Old Jan 4, 2005 | 11:44 AM
burnout289's Avatar
Default Re: camber problem (slwkaos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slwkaos &raquo;</TD></TR><TR><TD CLASS="quote">I had that camber kit on my last gsr and it fixed my problem. The only thing is, is that you are going to have to get your wheels realigned. When I put them on my car it pushed those wheels so far outa alignment. But yeah they do work and are easy to install.</TD></TR></TABLE>
well, the whole point of a camber kit is so that you can make adjustments so unless you have the equipment at home, you have to get an alignment. and you should also get an alignment each time you adjust the height [toe and camber are affected by this].
do any kits out there also allow you to adjust caster? I have heard there are, but haven't seen any.
Old Jan 7, 2005 | 10:35 AM
ImportAutoPerformance.com's Avatar
Don't go with generic kits. You will kick yourself in the a** later. Cambers are an integral part of your suspension, if they fail, it will get ugly. You can't go wrong with Ingalls or SPC. The skunk2 and Omni kits are good quality as well. Check us out at: http://www.camberkit.com Contact me if you have any questions.
Old Jan 7, 2005 | 10:14 PM
burnout289's Avatar
Default Re: camber problem (peteriap)
those Ingalls kits....where do they mount? I don't see any complete adjustable upper control arms for the DA. it says they replace the factory "uprights" but I'm not sure what that means.
great prices, though! lowest price I've seen on a DC header so far [new].
::edit:: oh, ok...I saw the FAQs on the site and it showed pics. neat! does anyone prefer one type over the other? meaning, adjustable balljoing vs. the ones that replace the control arm mounting points. thanks.
Modified by burnout289 at 11:28 PM 1/7/2005
Old Jan 7, 2005 | 10:35 PM
The only complete replacement I know of for the DA are the Vision upper A-arms. They're kind of hard to find and you will still have negative camber with them, they're not really meant for the street.
The ingalls front kit goes between the upper A-arm and the mount points allowing the arm to slide in and out. I have heard that the ball joint kits are known to slip sometimes but I don't know if this is due to design flaw, installation problem, or if it's been corrected.
The rear kit replaces the upper arm with an adjustable threaded piece.
Old Jan 7, 2005 | 11:13 PM
importdude2000's Avatar
Default Re: camber problem (MolecularIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MolecularIntegra &raquo;</TD></TR><TR><TD CLASS="quote">The only complete replacement I know of for the DA are the Vision upper A-arms. They're kind of hard to find and you will still have negative camber with them, they're not really meant for the street.
The rear kit replaces the upper arm with an adjustable threaded piece.</TD></TR></TABLE>
the visions still have negative camber with them is beucase the a arm vision makes for DA's are for race
so it gets more CAMBER
thats y
VISION A ARMS DOES NOT HELP camber
mikej94civex
Suspension & Brakes
May 27, 2010 05:49 PM
Don JD
10
Sep 23, 2009 08:04 AM
noz
Suspension & Brakes
Feb 18, 2009 07:53 PM
The Si
Suspension & Brakes
Feb 5, 2007 09:03 PM
typeSwarrior
Jun 8, 2002 06:18 AM
