JDM ITR exhaust fit onto a USDM GSR cat???
yeah I was planning to buy the whole JDM exhaust system but I might wait on the header.. u guys think the JDM ITR exhaust will fit onto a stock gsr cat?? if not how about a 2 1/4 cat with the stock three bolt flange weld on to it( thats what the muffler shop did on my car when I upgraded my stock cat.. just basically cut off the inlet and outlet on the stock cat and weld it onto the carsound cat that had 2 1/4 piping...)
Won't work without having to modify it. I can't say for sure though since exhausts on GS-R's from 94-99 and 00-01 are different, and you did not specify which year your car is. The JDM ITR header is longer than USDM ones. The axleback portion would fit though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackSage »</TD></TR><TR><TD CLASS="quote">I believe it goes like this
jdm itr exhaust = 94-99 usdm gsr
usdm itr = 94-01 LS,00-01 gsr</TD></TR></TABLE>this is correct. since you have a 94 gsr, it will fit with no modification needed.
not sure if you guys are answering my question correctly> I am wondering if a JDM ITR exhaust will bolt right onto a stock gsr cat.... maybe that'll clear it up... I hope it'll work but just want to make sure before I buy it..thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ringbearer020 »</TD></TR><TR><TD CLASS="quote">not sure if you guys are answering my question correctly> I am wondering if a JDM ITR exhaust will bolt right onto a stock gsr cat.... maybe that'll clear it up... I hope it'll work but just want to make sure before I buy it..thx</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy »</TD></TR><TR><TD CLASS="quote">this is correct. since you have a 94 gsr, it will fit with no modification needed.</TD></TR></TABLE>
isnt that the answer your looking for?
It'll work if you have a 94-99 GSR.
If you have any other teg you'll have to chop off about 5" off the midpipe and reweld the flange.
It will bolt right up
well i finally took it to the exhaust shop to get it done.. well it fit pretty well except they had to enlargen the flange holes on the JDM ITR exhaust in order for it to fit..so its not perfect fit.. other then that everything was smooth..
calvinx29
Jan 31, 2006 11:53 AM
NumberB
Southwest (Sales)
Jun 27, 2005 02:40 PM
Tommy_Gunns
Apr 13, 2004 12:45 AM
