whats the difference between a 96-98 and 99-00 floor harness?
the reason i ask this is becuz i have everything necessary to do power window conversion in my 99 hatch, except for the floor harness. Its been a bitch hunting one down, so im just gonna go to the dealer. majestichonda.com has a 99-00 ex floor harness for $168, but the 96-98 ex harness is only $105. But since the door panels and door harness i have are from a 00 si, i just wanted to know if i would be able to save 60 bucks and make the 96-98 harness work.....
-eric
-eric
Quite a few differences, mostly number of wires in plug and number of plugs. Definitely stick with the same model type, 96-98 with 96-98 and 99-00 with 99-00. They will not plug into each other with modifications.
there are differences... however, you can use either one... if you want everything to be plug and play you must use the floor harness of your year car... I didnt bother going through the hassel of finding one of my year 96-98... I used one from a 99si... I cut all the wires not pertaining to the power windows, locks and mirror... then I cut all those clips and spliced it together. Used a relay and inline fuses just like it is when it comes oem. Heres my little write up...
http://www.sencless.com/powerwindows/index.html
i recently did the same setup as u did i have a 96 dx coupe i install doors from a 98 ex with a floor harness of a 00si i had to cut some wires but i have like 7-8? remainin wires what or how do i get power to those remainin wires. statis of the door: NOThing works lol so i been driven around with the windows rolled up thank god i have A/C i just need soem tips on how u do it and how u convert the wires
Type-RBo1
16
Jul 26, 2007 07:23 PM
