Three windows is not work
Old Jan 3, 2005 | 10:43 AM
Harvz's Avatar
Default Three windows is not work
Can anybody tell me what might be the problem of my three windows of my 93 Accord, only the driver side window is working. I already checked all the fuses both under the dash fuse box and uder the hood fuse box, it seems they are all okay. I dont know what else I should check.
It happened after I change the face of the in dash gauges with a reverse white gauge face. As far as I know i didn't touch or disconnect any wirings related to a window connection. I only disconnect the plugs to the in dash gauge. But I'm not realy sure if that migh be the cause.
I'll appreciated your help-
Old Jan 3, 2005 | 10:59 AM
uncle_el's Avatar
Default Re: Three windows is not work (Harvz)
- window control (happen to mess with any wiring in the door?)
- relays for the windows
- window motors (doubtfull all 3 at the same time, but then again stranger things have happened)
- something else
Old Jan 3, 2005 | 11:04 AM
SpeedFreak77's Avatar
I don't know if it's the same thing but I have a 94 and my window switches went out. The driver's controls but just the opposite, thought it was the motor and ended up being the switch's. Do your widows go up using the switches on each door? May possibly be the problem. When mine went out it was all the sudden my window was down on a nice day and then wouldn't go up. At least it's a start.
Old Jan 3, 2005 | 09:25 PM
briq4's Avatar
Default Re: Three windows is not work (SpeedFreak77)
Did you make sure that the window lock out switch is not turned on? for some reason Honda Cheaped out and when that switch is in the off positoin even the drivers side switches will not open the other 3 windows.
Old Jan 4, 2005 | 12:35 AM
RUBZERK's Avatar
unlock the windows on driver door
Old Jan 4, 2005 | 04:42 AM
Harvz's Avatar
Default Re: Three windows is not work (RUBZERK)
Damn Im so stupid. I forgot that one.
Thankz Guys, I appreciate it -
Old Jan 4, 2005 | 05:56 AM
You are kidding aren't you?? Please say you are.
Old Jan 4, 2005 | 06:22 AM
Stew Pidasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harvz &raquo;</TD></TR><TR><TD CLASS="quote">Damn Im so stupid. I forgot that one.
Thankz Guys, I appreciate it -</TD></TR></TABLE>
Way to start a new year lol
Old Jan 4, 2005 | 06:42 AM
uncle_el's Avatar
Default Re: Three windows is not work (Stew Pidasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stew Pidasso &raquo;</TD></TR><TR><TD CLASS="quote">
Way to start a new year lol </TD></TR></TABLE>
indeed. i guess sometimes the simplest answer is the most likely explanation. hadn't even thought of that one!
dewey316
Jan 4, 2014 01:50 PM
ekkscott
Honda Civic (2001 - 2005)
Feb 5, 2012 09:27 AM
pldwelle
Sep 22, 2010 08:39 PM
tiptopEBPcivc
12
Aug 15, 2009 03:26 PM
Terabass
Jul 1, 2008 12:41 PM
