Radiator repair
Old Jan 3, 2005 | 08:54 AM
mrlegoman's Avatar
Default Radiator repair
I got a radiator from a wrecked EVO 8. It has a small 1/8" hole in one of the colling fines. My grand plan was to take some aluminum welding rods and a propane torch and 'weld' a seal over the hole.
Should it be that simple or am I just going to make a mess?
Old Jan 3, 2005 | 02:51 PM
dfoxengr's Avatar
Default Re: Radiator repair (mrlegoman)
once a friend had a pinhole and wa leaking fluid, so i sandwiched a lot of rtv sealant in between 2 small square pieces of thin aluminum sheet. then used a ziptie to go through the fins on each side of the squares, and ziptied it tight. still works fine. no problems
Old Jan 3, 2005 | 03:27 PM
toolowsol's Avatar
Default Re: Radiator repair (hybridvteceg)
I soldered up a radiator once, it held up until I sold the car (3years+)
Old Jan 3, 2005 | 05:08 PM
HamiltonRex's Avatar
Default Re: Radiator repair (toolowsol)
it will work!
Old Jan 3, 2005 | 06:52 PM
AccidentproWn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">I soldered up a radiator once, it held up until I sold the car (3years+)</TD></TR></TABLE>
I have a similar story. I had an aftermarket 2 row radiator for a CRX and the radiator fan was bent and owned half of the radiator with nice giant holes. So I cut it in half and soldered some metal on the endtanks. Turned out to be a nice halfsized radiator for a CRX.
Old Jan 3, 2005 | 08:05 PM
RMF
Guest
Posts: n/a
Default Re: Radiator repair (AccidentproWn)
Let the painter do the painting
and let the plumber do the plumbing Get it?
Old Jan 3, 2005 | 10:52 PM
turbo gli's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman &raquo;</TD></TR><TR><TD CLASS="quote">I got a radiator from a wrecked EVO 8. It has a small 1/8" hole in one of the colling fines. My grand plan was to take some aluminum welding rods and a propane torch and 'weld' a seal over the hole.
Should it be that simple or am I just going to make a mess?</TD></TR></TABLE>
no way man .. that will not work .. u wont even get the metal hot enough to weld .or solder ..
use some two part epoxy .. that stuff that comes in a tube and looks like gum .. i used it to patch a 1/2 hole in my rad .. worked till i sold it .. **** works .. the the one that is solvant safe and adhears to metal .. DO NOT use the **** u put threw the coolant system to patch holes ..
Old Jan 4, 2005 | 05:39 AM
19civic93's Avatar
Default Re: Radiator repair (turbo gli)
either have it tig welded or use por 15 epoxy putty. here's the specs and link for it.
Tensile Strength: 4,000 psi --- Compressive Strength: 12,000 psi --- Bond Strength: 375 psi ( ASTMD 1002) --- Dielectric Strength: 300 Volts/mil (ASTMD 49) --- Coefficient of Expansion: 4x10 to the minus 5th power in/inºF --- Maximum Use Temperature: 350º F (continuous) --- Hardening Time: 60 Minutes at 75º F (doubles for every reduction of 5ºF) --- Color: Light gray --- Specific Gravity: 1.95 --- Resistivity: 2x10 to the 10th power ohm cm at room temp. --- High Vacuum Leak Rate: &lt; 3x10 to the minus 8th power atm. cc / sec. (2 sq. in. surface area evacuated bulb immersed directly in liquid Helium) --- Thermal Conductivity: Roughly comparable to Nylon at 2-4º K
http://www.prp-porshop.com/por-15-epoxy-putty.htm
eecc
Acura TL, RL & ZDX
May 14, 2005 03:29 AM
tkHBseries
Feb 19, 2005 06:48 PM
Superhatch
24
Sep 20, 2004 10:13 AM
