Misfire code after H22A4 > H22A swap? Any thoughts?
Old Jan 3, 2005 | 08:08 AM
gerhard's Avatar
Default Misfire code after H22A4 > H22A swap? Any thoughts?
My H22A4 > H22A swap went flawlessly.
The engine runs perfectly... except I got 1 code the other day after about 140 miles of driving.
I got a code 70 or 71 - Misfire Detected Cylinder #1
I've got new wires, new plugs (gapped correctly), and everything, I mean everything, was checked and cleaned during assembly.
However, I think that I may have been about 2mm off with the alignment of the cams when I set them to TDC for the lash adjustment on #1.
I'm assuming that I may have adjusted #1 a little to tight.
Would that cause an occational misfire code?
I have been having issues with the OEM distributor, but I've got another ignitor on the way... I plan on swapping that out just to be safe.
Gerhard
PS Yes, I'm using 92+ octane gas.
Old Jan 3, 2005 | 07:51 PM
Keith's Avatar
Default Re: Misfire code after H22A4 > H22A swap? Any thoughts? (gerhard)
How are your injectors? What did you use? OBD1 or OBD2?
Keith
Old Jan 4, 2005 | 04:13 AM
gerhard's Avatar
Default Re: Misfire code after H22A4 > H22A swap? Any thoughts? (Keith)
AS far as I know my injectors are fine.
I used the OBD-II setup from the old motor. So the entire car is OBD-II with the P5M ECU.
I'm not getting this all the time... just once so far.... but I don't want a lean codition and a misfire to happen to much...
Old Jan 4, 2005 | 08:31 PM
Keith's Avatar
For jokes, why not mark and swap the injectors from cylinder to cylinder to see if the miss fire follows it...
Keith
Old Jan 5, 2005 | 04:32 AM
gerhard's Avatar
Ok... that's an interesting idea....
They were fine before the swap... but I guess it's possible that the H22A is a little more fuel hungry?
I'm going to re-adjust the valve on #1... and then put in the new ignitor and see what happens.
Old Jan 5, 2005 | 01:46 PM
gerhard's Avatar
Well,
I was able to do the valves this afternoon. I can tell you that they were all a little tight. Especially - Cylinder #1.
So I replaced the ignitor (using some heat sink grease on the back) and put everything back together.
Started the car... no codes.
So... time will tell.
The valve train was certainly a little less noisey. Honestly, I think the problem was the very slight difference between the cam gears in the H22A and the H22A4. I can't put my finger on it exactly... but my old motor looked different when I had the cam gears aligned.
Robert Groth
Aug 27, 2018 12:05 PM
Sns8504
Oct 22, 2017 05:56 PM
hulk_22
Jul 31, 2006 03:34 PM
GR
Mar 22, 2006 06:27 AM
Accord_Kid
Apr 28, 2005 08:01 PM
