Still leaking oil after 2 attempts of fixing????
Old Jan 3, 2005 | 08:03 AM
DrewQ1's Avatar
Default Still leaking oil after 2 attempts of fixing????
I'm still getting oil in my spark plug tubes, after i have changed the seals twice, what can be the problem????? someone help me out and let me know.
Edit: Will that also cause for me to burn oil or is it just me cause I put about 3k miles about every month or so on my car which is about half a quart every other week or so.
I just realized i didnt put the breather hose or whatever hose that is back in that hole on top of the valve cover. Now i'm hoping maybe thats the reason i'm still getting oil in my tube seals, But the first time i did it, i remember to put it back in, but in case thats not the problem, what could it be?
Modified by DrewQ1 at 11:38 PM 1/3/2005
Old Jan 3, 2005 | 08:18 AM
Quiks66's Avatar
Default Re: Still leaking oil after 2 attempts of fixing???? (DrewQ1)
Buy some HondaBond to fully seal the rings in the valve cover. It's the same stuff to use when sealing the corners of your valve cover gasket if reusing an old one. You can buy it at Honda or Acura dealerships. Good stuff, high temp too.
Old Jan 3, 2005 | 09:35 AM
DrewQ1's Avatar
Default Re: Still leaking oil after 2 attempts of fixing???? (Quiks66)
are you sure, cause when i bought the seals it said dont use with anything, i used fel-pro and the one before that i used oem straight from the dealership, and i light put oil around the seals so they would crimp up.
Anyvbody have any ideas?
Old Jan 3, 2005 | 02:42 PM
DrewQ1's Avatar
bump!
Old Jan 3, 2005 | 07:39 PM
DrewQ1's Avatar
i'm bored so heres a bump!
Old Jan 3, 2005 | 07:52 PM
Cjsls's Avatar
hmm...how much oil we talking here? is it in all 4? tightened valve cover down nice and snug??
Old Jan 3, 2005 | 08:16 PM
DrewQ1's Avatar
Default Re: Still leaking oil after 2 attempts of fixing???? (Cjsls)
its in all 4 but not all the same time, one may start to have more than the other at first. well when i pull the pligs out the oil is about an inch cover the plug.
Old Jan 3, 2005 | 09:48 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
dont use feel-pro.. use OEM... once you get the honda gaskets, compare them to the feel-pro's... quality is hands down... i bet this is your problem.. i used a shitty valve cover gasket on my hatch, and ended up getting a OEM one, to do the job right.
some **** you can get away with aftermarket.. but when it comes to gaskets.. i like to stay OEM. ESSPECIALLY HEAD GASKETS.
Old Jan 3, 2005 | 10:59 PM
Sack Master's Avatar
Default Re: Still leaking oil after 2 attempts of fixing???? (Built B16A)
Sounds to me as if you have some blow by and its too much pressure for those little seals to handle. Or possibly some other problem. I've had no problems using fel-pro gaskets before.
If you have to use honda-bond or silicon for it to seal then something is not right in the first place.
Old Jan 4, 2005 | 06:01 AM
DrewQ1's Avatar
Default Re: Still leaking oil after 2 attempts of fixing???? (Sack Master)
Well i havent used any sealeants yet.
What would cause a blow by and what is that?
Any idean why thats happening?
Old Jan 4, 2005 | 06:02 AM
DrewQ1's Avatar
i've done it 2x already i'm gonna attempt a 3rd time and use some honda-bond.
Old Jan 4, 2005 | 02:31 PM
DrewQ1's Avatar
any new ideas?
1997accordlx
Jan 7, 2010 12:32 PM
jakop92
Nov 15, 2009 11:33 AM
project midnight
Sep 17, 2006 09:43 PM
DrewQ1
Jan 4, 2005 02:28 PM
Pinhead
Jan 5, 2002 12:29 PM
