I'm goin in
Old Jan 7, 2002 | 10:35 PM
Deadly-Lude's Avatar
Default I'm goin in
My car has been emiting a considerable amount of smoke and is not running right. So I have been thinking since I am gonna have to change the timing belt within 6 months i thought I might as well do some work. I was thinkin about port and polish the head. Up the compression and maybe a crank swap? Now here are the questions. Which pistons(budget)? Does the H23 crank really work and make a difference? What about the h23 crank pulley and harmonic balancer. I heard that you could rev higher with it. Is it worth getting a JDM type S head? Should I P&P my stock head and who could do it properly at a good price? Thanks for any answers. Let me know if anybody is selling there stuff at a descent price.
Old Jan 8, 2002 | 07:26 AM
Greyout's Avatar
Default Re: I'm goin in (Deadly-Lude)
type S is not worth it. Build your own, using crower cams.
Old Jan 8, 2002 | 07:29 AM
laughinxxx's Avatar
New User
I would think a port and polish on a stock head would flow air just as well as a Type S head and it will definitely be cheaper. JE makes good pistons and JUNs are just too expensive. If you don't plan on going with a mild NA setup you could probably get away with arias pistons to save some money.
Old Jan 8, 2002 | 08:40 AM
JG Luder's Avatar
Default Re: I'm goin in (laughin2.2)
Dude, Arias pistons are just as good as JE. I haven't had a single moments trouble out of mine (and I don't have a *mild* N/A setup). And they aren't any cheaper than JE.
Old Jan 8, 2002 | 10:22 AM
Default Re: I'm goin in (Jonesy69)
How much does resleaving cost? I was thinking about the JE 11.5:1 with a thinner head gasket.
Old Jan 8, 2002 | 10:43 AM
laughinxxx's Avatar
New User
I stand corrected.
**Laughin walks off to sulk in a corner**
Old Jan 8, 2002 | 12:45 PM
ASR's Avatar
ASR
New User
As you can see below i just got done with my rebuild, its take $$$ and time so good luck, its worth it in the end!
Old Jan 8, 2002 | 07:12 PM
Default Re: I'm goin in (ASR)
sounds like you have a pretty deadly setup there
h22Hatchy
Apr 5, 2018 01:52 AM
Ftrceo
May 19, 2012 06:47 PM
LobeSex
Apr 5, 2009 06:42 PM
thehatchninja
Sep 15, 2005 08:03 AM
WiteSiprelude
Oct 8, 2004 06:03 AM
